M54 DISA Valve rebuild - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 07-04-2020, 02:46 PM
rav31 rav31 is offline
Mein Auto: 2001 540i/6 Tisilver/gray
In light of the (2) posts below by McLarenBMW concerning the upper pivot pin damaging the engine, I want to replace or rebuild my current OEM DISA valve in my '05 330icc ZHP with 92K. I was looking for your suggestions as what to do. A new one from FCPeuro is $375; the Rein unit is $154; they offer a repair kit (with pin) for $50; I found the Aluminum kit from X8R for $90.
What are your recommendations? NEW or REBUILD? I feel that I should stay away from the "PIN" units due to the possible issues of the pin being digested.
BMW CCA #132981 Tarheel Chapter,
Old 07-04-2020, 02:51 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
Use this rebuild kit.
https://germanautosolutions.com/prod...sa-repair-kit/
Thread closed.
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
2002 330ci convertible - 5 speed
Past:
2012 X5 Diesel
2012 Countryman S All4 - 6 speed
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
1988 325i convertible - 5 speed
1969 2002 with tii and 5 speed conversions
Old 07-04-2020, 05:27 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Yes, I also vote for the G.A.S. kit as well, you will not regret it. After a rebuild with their kit, you will have a DISA valve that is superior to a new factory unit.
The road goes ever onward....
(R.I.P. Jever)
Old 07-04-2020, 06:01 PM
meinbills meinbills is offline
Mein Auto: 2001 325ci/2003 330i
+100 G.A.S. kit. The only thing I am concerned about my DISA is the o-ring gasket that might leak in the future, not the pin getting loose.
Old 07-04-2020, 06:12 PM
McLarenBMW McLarenBMW is offline
Mein Auto: BMW E46 330Ci 5MT
I'm glad my misery can bring awareness to this issue, good luck my friends
Old 07-04-2020, 06:16 PM
Also X8R and GAS are the best kits available. Be very careful when removing your old DISA as the pin could be loose and prone to falling out like mine. If you can detach the brake booster hose and lift the heat shield out for more room then do so, the best way to get it out is to aim it downwards so the pin can't fall out
Old 07-05-2020, 04:53 AM
Great feed back! Thanks....One question...
Have you guys that recomment the GAS Kit actually installed it on your DISA?
FredoinSF
Fast Bob
meinbills
McLarenBMW
Old 07-05-2020, 05:29 AM
tttomttt tttomttt is offline
Mein Auto: 2005 530i, 05 X5 3.0, 04
I would first make sure the diaphragm does not leak as that is another source of a failed disa valve. If it in fact passes the diaphragm test I would not hesitate to rebuild it with the GAS kit.
Old 07-05-2020, 05:48 AM
Good point tttomttt. Will check it out
Old 07-05-2020, 08:34 AM
u.nanimous u.nanimous is offline
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
My son installed the GAS kit as part of the $400-ish of parts on his $800 project 2001 330xi. A few months later the car was given to his older sister who has since put well over 10k miles on it. That full story is posted around here somewhere.
The GAS kit has been THE recommendation for years, pretty sure it has mention in an old DISA thread started by Blubee (E39 foruum), I believe the key word was grenade.
Posted through Tapatalk downloaded to my neural implant
2005 Venture Extended LT - what else you gonna drive when you have 6 kids, cargo and still want better than 10MPG
1999 740iA - long term project/summer DD
2000 Impala LS - RIP 12/23/2016, officially totaled by insurance company
2001 330xiA - fXtXeX/son project - now April's car
2008 335xiA - winterbeater Impala replacement
2002 530i/5 - 2.5 years searching...and it is John's car
1989 535i/5 - the spare car
2002 325xiA - to be Charlotte's when she gets her license (?2019?)
Old 07-05-2020, 09:33 AM
Yes, I installed the GAS kit on my 325Ci. Looking at the X8R kit, it seems to be similar to the GAS kit in design so I think it would be OK as well. However, since we took the plunge for you and used the GAS kit already and have no problems, why do you want to be the trailblazer on the X8R?
Old 07-05-2020, 10:31 AM
TheHockeytowner's Avatar
TheHockeytowner TheHockeytowner is online now
RIP #9
Mein Auto: 2003 330Ci
I installed G.A.S. DISA flap kits on my 525i and 330Ci. Highly recommend this kit, Gary does great work.
Go Wings!
Old 07-05-2020, 12:40 PM
cn90 cn90 is offline
Another vote for G.A.S. rebuild kit for M54...
- We have three (3) M54 engines at home, and all 3 have G.A.S. rebuild kit installed.
- As long as the vacuum diaphragm of the DISA is OK, then you can rebuild using G.A.S. kit.
My recommendation:
1. At 100K, rebuild using G.A.S kit.
2. At 200K check the diaphragm, if bad, new Genuine BMW DISA.
Repeat the cycle every 100K...
Old 07-07-2020, 08:18 PM
Fifty150hs Fifty150hs is offline
Mein Auto: SF Bay Area
My recommendation:
I put the GAS kit in my E53. Great kit. I have over 250,000 miles now and the DISA diaphragm is fine.
Old 07-08-2020, 06:43 AM
RIP #9
My recommendation:
cn gives good advice here but I offer an alternative: you can replace the vacuum diaphragm.
Go Wings!
Old 07-08-2020, 06:57 AM
Never heard of replacing the diaphragm before. Where do you get it & how to replace it. Interesting idea.
Old 07-08-2020, 08:43 AM
RIP #9
The large auction site has them, but I picked mine up from a Russian supplier when I bought a replacement OFH check valve. It's worth a google at least.
The biggest challenge is not breaking the DISA when removing the vacuum membrane "cover" or whatever you like to call it. AFAIK it's also only for Genuine BMW DISA valves and not parts like Uro, etc.
Go Wings!
Old 07-13-2020, 04:04 AM
SteveEdgerton SteveEdgerton is offline
Mein Auto: 2003 Z4 2.5i
If your diaphragm is leaking G.A.S. Did offer a DISA that already had their kit installed.
Old 07-16-2020, 11:03 PM
yoheezie yoheezie is offline
Mein Auto: 2002 E46 325i Sedan
Definitely make sure the DISA still has a good diaphragm. I'm waiting on some diaphragms from Russia. Once I do get them in, I'm going to replace the diaphragm on my DISA and use a donor DISA to harvest a cap. The way they're built, you can put the cap on the diaphragm, but once it's on, it's on... I'm HOPING that I can use a donor to harvest that cap by going nuts with a Dremel. When the time comes, I'll post my progress.
