BMW memory climate control and settings - Page 2 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 08-27-2004, 07:19 AM
Fifty_Cent's Avatar
Fifty_Cent Fifty_Cent is offline
Pure Natural BMW Muscle!
Mein Auto: 320CiC
Individual BMW keys can be COMPLETELY customised by each driver.
I am talking about***********:
Climate control settings
electric seat settings
electric mirror settings
Central locking settings
Refer to "CAR AND KEY MEMORY OPTIONS"
Do a search in the forums, you will find what you need here.
Old 08-27-2004, 08:20 AM
vimal vimal is offline
Mein Auto:
Originally Posted by freq019
I had an E34 540i and it had a timer that you could set to say 10 min before you go out to the car after work and it would blow the air out of the cabin and cycle in new air. I don't think it ran the a/c but I'm not sure. The problem was you had to set it everytime you wanted to use it and I forgot a lot. Not sure if it did any good I think opening the windowns via remote is better.
WAW!!!
Thats seems to be at least partially helpful. Cycling new air.
  #28
Old 08-27-2004, 08:21 AM
Mein Auto:
Yes, you are right. We can set climate control setting thru key. The original question is, will the AC turn on and run, when you remote unlock your car, when the engine is still turned off.
  #29
Old 08-27-2004, 09:28 AM
Jim Seattle's Avatar
Jim Seattle Jim Seattle is offline
Chewbaca is a pimp!
Send a message via MSN to Jim Seattle
Mein Auto: 2000 323Ci
I know today's X5 has this functionality as well....
  #30
Old 08-27-2004, 10:50 AM
Mein Auto:
So without engine running, AC will be on?
Won't it drain the battery?
  #31
Old 01-25-2019, 06:52 PM
Katie35805 Katie35805 is offline
Mein Auto:
Hi Everyone,
Could really use your help. I just purchased a X5 sDrive36i. I was told the climate control timer (from the app) would heat/cool my car based on the settings in the vehicle when I turned it off. I can't get it to work. It's only pushing outside air through the car. Please tell I haven't been scammed!!!
  #32
Old 02-15-2019, 10:16 AM
scwilsonct2 scwilsonct2 is offline
Mein Auto: 328xi SDN, 335iCPE, X5
The memory setting is just that - memory; it does not turn on/off the system. The key stores the last temperature setting (in addition to seat, mirrors and I believe audio) for that key. If you want to turn on the system before you get into the vehicle there are two timers in Climate using the iDrive system. It allows you to activate the climate control before entering the vehicle. I have never used it so I have no idea how it works or if a remote starter is required. Perhaps another member can educate us both on that.
