auxiliary coolant pump line disconnection or short circuit to B+ - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 F15 (2014 - Current)
The all new F15 BMW X5 started production August 2013 as a 2014 model year. The new X5 arrives in sDrive35i (RWD), xDrive35i, xDrive50i and a diesel xDrive 35d.
Old 08-21-2019, 09:07 AM
mudbug mudbug is offline
Mein Auto: BMW 520ia
Hi,
I ran first time on my F15 2015. I got this error code:
80436A auxiliary coolant pump line disconnection or short circuit to B+,
Could you please guide me the right direction to figure out what is wrong?
Mudbug
Old 08-21-2019, 09:20 AM
Doug Huffman's Avatar
Nuclear engineer
A Diagnostic Trouble Code error number does not identify a broken part to be replaced but identifies a symptom that may be caused by any number of failed components or adjustments to be differentiated amongst by execution of a BMW Test PlanŠ guide through the fault tree.
A Brush-Less Direct Current - BLDC - motor is plenty complicated by itself. It is commanded by Pulse Width Modulated PWM signal from the ECU.
I suggest taking it to the authorized BMW Service Center.
Old 08-25-2019, 01:46 PM
Thanks for info. Could you please guide me where this the pump location? I get this info from report. My caris
F15 xdrive 2.5D
The auxiliary coolant pump for the heating/air conditioning circuit must not be confused with the auxiliary coolan
t pump for the charger or cooler or the turbocharger coolant pump (see installation location)
