Tips/Recommendations for oil change? - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 09-17-2012, 01:19 PM
Jerrybr100 Jerrybr100 is offline
Mein Auto: 2003 330ci
Hey so I'm a new owner of a 03 330ci and I'm about due for an oil change and I've been thinking about doing them my selves since I drive 5k miles a month in the car do I'll be needing them frequently. If y'all could jus help me answer whatever u can the help will be appreciated.
Is changing oil and filter on this car simple for someone not to mechanically inclined?
Is the BMW dealer the only place to buy filters?
If this was ur car which type of oil would you be using?
How often do I need to change the oil?
And if you have any other tips, recommendations, or good DIY videos it all be appreciated!!!
Old 09-17-2012, 01:25 PM
moiz21's Avatar
moiz21 moiz21 is offline
Mein Auto: '99 323i 5-Spd
Yes it is quite easy to change the oil without being a mechanic. Personally never touched a car before buying mine. Learned everything I have on it.
Use BMW approved oil. Either go to the dealer, or Mobil 1 0w-40.
No real trick to it. Raise the front of the car, open the drain bolt, remove the cap on the filter in the engine bay, let it drain and voila. You are done. Close the drain bolt, replace filter and add new oil. Very Simple to do.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S/ 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
Old 09-17-2012, 01:46 PM
Dave 330i's Avatar
Dave 330i Dave 330i is offline
The King of Common Sense
Mein Auto:
Is changing oil and filter on this car simple for someone not to mechanically inclined? Yes
Is the BMW dealer the only place to buy filters? No, I buy them online, OEM Mann HU 925/4X. I buy in bulk of 10 for $52, free shipping.
If this was ur car which type of oil would you be using? Mobil 1 0-30 or 10-30. Porsche recommends Shell synthetic, but I think Shell is in bed with Porsche.
How often do I need to change the oil? There is a mileage indicator when you turn the ignition on. It is not very sophisticated sensor. The correct number is 667 gallons of gasoline consumed. That equates to 22.49 mpg average over 15,000 miles.
http://bimmer.roadfly.org/bmw/forums/e46/121712-1.html
Author: Dave 330i 5spd SP on 2001-11-11 at 23:24:50
Message: The OBC does not know when you changed your oil. You need to reset it yourself using the OBC. I used to do it every 5K, now 10K with 137K on the ODO Every 10K is an easy reminder. The tech who replaced leaky gaskets to the valve covers told the SA that I had the cleanest engine he had ever seen. Quite a compliment.
You need a 36mm socket to remove the lid to the filter housing. It is located on top of the engine, right in front of you, very easy to do. You will also need a 18mm socket to remove the drain plug. To reach the drain plug, you may have to remove the black plastic splash guard. My 330i does not have the splash guard. I don't use ramps to get under the car. I back the front of the car to the dip between the driveway and the street. I can reach the drain plug by crawling in just a little. Of course, replace the o-ring to the filter housing, and the copper washer to the drain plug. Put in 6.5 quarts of oil, and top off later as necessary. Now, you need to know how to reset the "dumb" oil service indicator. That will be another thread.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton.
Old 09-17-2012, 02:30 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Or just buy yourself a Mity-Vac and you won`t even have to get under the car to change the oil. It will pay for itself after 2 oil changes (which most of us perform at approx. 7500 mile intervals).
Good luck !
http://www.amazon.com/dp/B0002SR7TC/..._df_B0002SR7TC
The oil capacity is 7 quarts, not 6.5 (it`s 6.5 LITERS, Dave :-)
The road goes ever onward....
(R.I.P. Jever)
Old 09-17-2012, 02:41 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Old 09-17-2012, 02:48 PM
Dave 330i's Avatar
Mein Auto:
Originally Posted by KrisL View Post
Is that oil you're drinking? I see the Mann filter box, but you were too drunk to replace the filter. Makes the job quicker, buy synthetic by 5 qt containers at Walmart, about $25 each.
Old 09-17-2012, 08:07 PM
Thanks for all the help I will definitely Check out the oil filters!!!
Also I know you stated a 36 and 18 mm socket, but are those the only tools that I would need?
Old 09-17-2012, 08:55 PM
Dave 330i's Avatar
Mein Auto:
yep.
Do get (2) Mobil 1 in 5 qt container at WalMart (if you have one). They are a lot cheaper than buy 1 quart at a time. I've never used that suction pump, but apparently it works well since that guy Kris L uses it. It saves the hassle of having to get under the car and removing the plastic sheet (you may not have it) and oil plug. But, I always felt that draining will flush out particulates than trying to suck them out.
Old 09-17-2012, 09:07 PM
lgr122's Avatar
lgr122 lgr122 is offline
Mein Auto: '04 e46 Touring M-Sport
yep.
Right, it's good to see for those special offers of quality oil already long before it's time to oil change. It's just smart if you have oil+filter ready waiting well in time.
Old 09-17-2012, 09:31 PM
Fast Bob's Avatar
Keeping it surreal
I`ve been looking for years, and have never seen Mobil 1 0W-40 in 5-qt. jugs at Walmart near me, they only have that particular weight in 1-qt. bottles.
And Dave, the Mity-Vac IS as effective as a gravity drain....
(R.I.P. Jever)
Old 09-17-2012, 09:51 PM
Dave 330i's Avatar
Mein Auto:
I don't think I mentioned 10-40. I use 0-30 or 10-30, or what ever they have. They are the same stuff. I doubt your engine knows the difference.
Old 09-17-2012, 09:55 PM
Dave 330i's Avatar
Mein Auto:
I'll look into it because changing oil in the 911 Turbo is a PITA.
Old 09-17-2012, 10:01 PM
Fast Bob's Avatar
Keeping it surreal
You are QUITE wrong about that....you obviously haven`t done your homework....
(a fine kettle of fish for the self-proclaimed "King Of Common Sense" )
(R.I.P. Jever)
Old 09-17-2012, 10:05 PM
Dave 330i's Avatar
Mein Auto:
My engine didn't tell me what it likes. So, I put in what I have. Next oil change will be 10-30 because that's what I have 2 jugs right now. The engine has 137K miles, and it is running strong. No problem with running it at 125 mph (GPS) on I-10 through NM. I didn't want to hit the limiter by going faster.
Old 09-17-2012, 10:28 PM
WhitexLightning WhitexLightning is offline
Mein Auto: 2001 330ci
2001 330ci oil type
Although I see the oil cap says casterol I see everyone talking about mobil 1. Which oil and weight is the most agreed upon best oil type and weight.
Old 09-17-2012, 11:29 PM
todd92 todd92 is offline
Mein Auto: 19 330iX, 05 ZHP
Sigh. Mobil 1 0W-40 is the ONLY grade that meets BMW LL-01 spec. It's only been posted 1000's of times here.
Old 09-18-2012, 12:35 AM
lgr122's Avatar
Generally all oils should be equivalent when they have same xxW-xx marking, but some brands are still way better than others.
Bit like with beers.
Can be two brands of beer which are generally same with same X,X%, but everyone who likes beer knows there's always difference, and even then you might get that other sometimes anyway, if it's very much cheaper.
Old 09-18-2012, 01:58 AM
So again I'm no mechanic jus think it's smart for me to try as early as possibly with this car to do my own maintenance so I was watching this vid and got a little confused by something in the vid because it almost looks like he is wiping down his filter and cleaning it instead of replacing it.
I probably saw things wrong and am on one right now, but you guys are really helpful so I figured id ask.
So far, this Mitty Vac is looking like a positive especially for someone changin there oil 7-8 times a year like I will be doing.
Old 09-18-2012, 02:43 AM
gesoffen gesoffen is offline
Mein Auto: Rainbow Unicorn!
Lots of other oils out there meet LL-01 specs. Lubrimoly, Total and a few others come to mind. Maybe you meant 0W-40 is the only Mobil 1 to meet LL-01?
----Brian
Old 09-18-2012, 04:24 AM
Yes, it's the only grade of Mobil 1 that meets LL-01, not 5W-30 or 0W-30 as mentioned in a previous post.
Old 09-18-2012, 04:29 AM
Dave 330i's Avatar
Mein Auto:
Do quick starts and stops to see he was wiping the dipstick. He never touched the filter. He was too drunk to think about changing out the filter. The filter box never moved in the vid!
Old 09-18-2012, 06:22 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2003 330ci (5 speed)
54 seconds in he replaces the filter.
Old 09-18-2012, 07:16 AM
Fast Bob's Avatar
Keeping it surreal
Maybe you should stick to kickin` it Gangnam Style, Dave....seems to be more your area of expertise....
(R.I.P. Jever)
Old 09-18-2012, 07:18 AM
Dave 330i's Avatar
Mein Auto:
My BAD!!!!!!!!!!!! I was brain dead for not watching the entire video because I normally change out the filter while the oil is draining out of the crankcase.
There are more than one way of skinning a cat, I'm sure you have heard of that one. I keep things simple. By draining the oil and utilizing the dip in the driveway, I have eliminated the need of the oil extractor and ramps. Of course, you can change the oil/filter the way you want. How long do I intent to keep my car? A long time.
Old 09-18-2012, 09:06 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
You put over 50k miles per year on your car?
Jeff R.
