Leaking oil in front of Engine. Cant find - Bimmerfest - BMW Forums
Old 08-15-2019, 05:41 AM
JohnnyTurbo's Avatar
JohnnyTurbo JohnnyTurbo is offline
Mein Auto: 2008 535i
I am at a loss.
Belt literally exploded in pieces so I changed that. Then the fun really began.
Oil was definitely leaking from the oil filter housing. I changed both oil filter housing gaskets. Still leaking somewhere else. Then I saw oil dripping from the oil driver oil cooler hose and the fan was blowing the oil on the front of the engine. I thought AHA I got you M-FER!! Changed both Oil cooler hoses w/O rings. No DICE!! It does not seem to leak at idle. It almost seems like the oil is getting picked up by the belt and slinging it everywhere. I am open to any suggestions. It looses oil really fast when I get on it.
I have used all OEM BMW parts btw.
I am so frustrated with this crazy thing. She is so much fun to drive but damn this thing is falling apart.
146K miles
2008 BMW 535i
Old 08-15-2019, 05:48 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Possibly the reason the belt literally exploded in pieces is for being contaminated with oil. Elastomers, belts, hoses, vibration reducer fail untimely for being contaminated with fuel, oil or coolant.
Very often pieces of belt get forced through the front main seal and into the interior of the engine.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 08-15-2019, 06:34 AM
twh twh is offline
Mein Auto: '06 530xi 6sp, '09 X5 3.0
If you clean off the engine front of all the oil sludge you should be able to find the source of the leak by following the fresh oil.
Old 08-18-2019, 04:44 PM
I removed the engine shrouds on the bottom and presure washed everything. Its all nice and clean now. I jacked it up and started it up. At idle it does not leak. After revving it up a few times I finally started to see a little oil right under the harmonic balancer. I see nothing on top. So it looks like the front main seal is leaking and hitting the belt then it slings the oil all over the place. Does this sound possible? Has anyone experienced this situation on their bimmer or am I way off base here? I am a hair line away from giving up and taking it my indie.
2008 BMW 535i
Old 08-18-2019, 06:33 PM
wcr3d wcr3d is offline
Mein Auto: 2013 535iX M Sport
As Doug mentioned that is the front main seal.
I would suggest the Indy.
Old 08-18-2019, 06:50 PM
DJtoad DJtoad is offline
Mein Auto: 2010 535i M Sport
While not all that difficult, the removal/installation tool and required sealer will cost you around $200. I'd just have a qualified BMW indie do the work.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus
Old 08-18-2019, 07:58 PM
twh twh is offline
As others have said, it can leak and unless you are an experienced DIY, I'd take it someplace.
But, you also have to satisfy yourself that your previous belt destroying episode didn't wrap the belt around the harmonic balancer and find it's way into the engine via the front main seal. That is not an uncommon problem with the N52 and N54 engines. You can search the forum for other cases and some have pictures of belt pieces in oil pans and timing chains and more. Now, typically, these cars that have had the catastrophic belt wrapped around the harmonic balancer don't run right afterward.
Old 08-19-2019, 01:06 AM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e83, e60
get rid of it...
your on a path to a engine loss,
Get rid of it now
Specializing In Breaking Things Professionally
15486372<-----
Old 08-19-2019, 01:46 PM
Well dang. I called my indie this morning and he told me the exact same thing. He said he will take everything apart and clean it all out for around 3k. He told me not to drive it, but to have it towed. For a second I thought he was pulling my leg until I got home and read this. OMG I drove this thing for to work and back when I thought I fixed the oil leak. I think Im going to cry.
2008 BMW 535i
Old 08-20-2019, 12:12 PM
bmrboy2008's Avatar
bmrboy2008 bmrboy2008 is offline
Mein Auto: 2014 535i M Sport
I feel your pain. I had to ask BMW to buy my 2008 535i back because of the dreaded HPFP and fuel injector issues. It went down 8 times before I turned it in. Time to get rid of it and get a new G30.
2014 535i M-Sport, Jet Black, Black Dakota Leather, Premium Package, Lighting Package, Multi-Contour Seats, M-Sport Suspension, Navigation, Harmon Kardon Stereo, 3M Tint
2008 528i Sport - Retired
2008 535i Sport - BMW Buy Back
2004 525i Sport - RIP
