Another Smog Thread - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 07-15-2013, 03:22 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Another Smog Thread
Forgive me, searching on my phone is a PITA and I don't recall if I've seen something quite this bad before.
Looked at a 325 over the weekend and it failed smog SPECTACULARLY. As in, well over the limit on each category at each engine speed. HC and NOx were almost double if I recall.
My question is, the O2 was reading about 3.5%. Am I correct in thinking the O2 is supposed to be 0 so perhaps it's just running horrifically rich from a failed O2?
I have a lousy picture of the smog report but I don't think it's legible, I'll upload if absolutely necessary.
Thanks guys.
C:\>Sent from my 386 using MS-DOS__
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 07-15-2013, 05:36 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
well, high o2 and nox indicates the cat is dead....
df
Old 07-16-2013, 01:07 AM
I Am The Machine
Now that I'm on a real computer I'll just type out the numbers.
1500 RPM
CO2: 13.9%
O2: 3.6%
HC: max 83, meas 136
CO: max 8.56, meas 9.44
NOx: max 635, meas 1135
2500 RPM
CO2: 14.3%
O2: 3.5%
HC: max 50, meas 142
CO: max 8.47, meas 8.54
NOx: max 117, meas 1613
So, sir DF, does this look like a failing cat still?
// Chad //
You're a derbanana
Old 07-16-2013, 11:00 AM
I Am The Machine
Re: Another Smog Thread
Paging DF, DC, and everyone else.....
Yeah I'm being a prick and bumping my thread early. Sorry. You'll get over it.
// Chad //
You're a derbanana
Old 07-16-2013, 02:45 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Mine was failing only with NOx so I think my cats were too cold, or my mix is too lean. Had fair CO and O2.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 07-16-2013, 07:28 PM
ahem,.....no, i won't get over it!!!
so there....
yeah, it looks as if the cats are dead, because with it running so rich, the nox should be almost nonexistant. unless it's running hot *making* nox trying to reduce the hc. in which case, you probably still need a cat, and need to fix what is killing/has killed this one....
i's also check the cooling system is up to snuff and the rest of the 'standard stuff' like plugs (probably fouled out pretty badly), and i would throw a new o2 sensor in it.
make sure the vanos is operating properly, too. high nox is apparently a red flag for vanos operation iirc....forget who had that, though. it's been forever since i have done an actual emission failure so i am getting a bit rusty with some of the details. sorry.
(you'll get over it, right??)
co2 is a bit low, so i would also check engine vacuum and fuel pressure.
then report back.
and do a compression test while you are at it.
and then you can come finish my yard for me, too.....
df
Old 07-16-2013, 08:34 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
I forget what year your 325 is but does it have an SAP and is the SAP working?
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 07-16-2013, 10:59 PM
I Am The Machine
It's not mine, just a car I am thinking about buying. It's a 95.
95 shouldn't have SAP, but even if it did what difference would that make? I thought that only ran for a few minutes after a cold start.
Cooling system appeared to be functioning just fine. Typical VANOS rattle but didn't feel badly affected.
The whole idea here is to find out how much money is the minimum I'll need to get it to pass smog so I can decide if I want to buy the car or not. If I can slap cats on it and call it a day I'll probably do it for the right price. If I need a long list of parts I can't get it for cheap enough to make me happy.
// Chad //
You're a derbanana
