DIY Upgrade Navigation CIC Hard Drive to SSD Solid State Drive - Bimmerfest - BMW Forums
Old 05-01-2015, 10:42 PM
tol4o tol4o is offline
Mein Auto: E92 M3 & X5D
I have been planning to replace the sluggish Toshiba 4200rpm mechanical drive to SSD on my 2011 X5D and finally completed the project.
The speed improvement is great. The upgrade is well worth
Pros:
- instant boot when you start the vehicle, no more BMW logo hanging on screen for 10 sec
- no more waiting for mechanical drive to spin and find the data
- Navigation is much more responsive, finds addresses quickly, faster zoom-in and zoom out
- noiseless
- shockproof
- low power usage
I decided to create this DIY for anyone who wants do this project and turbo charge the CIC
It's for BMW X5 E70 but it would work for other models as well
What you need
- 128GB ATA-6 / PATA SSD - I got ZHEINO SDD of eBay for $92 shipped
- ATA-6 / PATA to USB adapter
- hard drive clone software - I used Partition Hard Disk Manager 15
- regular phillips screw driver
- flat screw driver
- Torx T9 screw driver
- plastic pry tool /optional/ - I used my fingers
You have to do bit by bit copy. They use their own specific file system and 1:1 mirror clone is the only option to have working drive after that. I wish I could expand the 12.7GB Music Storage partition but I didn't find a way to do it. As you can see there are 43.4GB left unused on the SSD
Use your fingers or plastic pry tool to lift the bottom of the ventilation exhaust and pull it up out of place
Step 1 - remove the two phillips screws
Step 2 - gently pull the plastic frame towards you and slowly pry out both sides to the bottom
Remove the two Torx T9 screws holding the HDD tray
With a flat screw driver carefully pry both sides little by little
Pull out the HDD tray
Remove the four Torx T9 screws holding the HDD in tray
Install SDD in tray and replace the four T9 screws
!!! IMPORTANT !!! - Remove the jumper before you slide the tray in
Slide the tray gently into place, don't force it hard at the end - go very slow
Install everything back in opposite order
- Torx screws
- frame
- phillips screws
- ventilation exhaust
Navigation loaded from SDD, old 4200rpm mechanical HDD retired /keep it as a backup/
2011 E70 X5 35D - The Ultimate Oil Burner
2008 E92 M3 6SP Silverstone II Matt, Schnitzer ACS3 Sport
2007 E81 123D 6SP (SOLD)
2004 E46 M3 6SP Imola Red (SOLD)
2004 X3 E83 2.5i Auto (SOLD)
1996 318ti E36 Hatchback 4-cyl 5SP Manual (SOLD)
Old 05-02-2015, 04:21 AM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '15 435i '10 535i '08 X5
WOW...thats a GREAT upgrade. What is the size of the Toshiba HDD you removed? Thanks.
Old 05-02-2015, 05:00 AM
TinyRK's Avatar
TinyRK TinyRK is offline
Ja mei!
Mein Auto: G12
That's a great little mod!!! Great write up. SSD FTW!
BMWCCA Member# 481324
Old 05-02-2015, 07:24 AM
smyles smyles is offline
Mein Auto: X5
Re music partition, it won't allow you to expand it after the copy process is complete?
Old 05-02-2015, 07:44 AM
It's 80GB Toshiba 4200rpm, slow spin, slow seek time, slow data transfer
Originally Posted by smyles View Post
No because when the software doesn't recognize the file system the re-size option is not available
Old 05-02-2015, 07:59 AM
PhreakShow PhreakShow is offline
Mein Auto: V70R
How about doing the same mod an an NBT, but of course with a larger SSD?
Old 05-02-2015, 08:33 AM
ard ard is offline
Resident Curmudgeon
Very nice!
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 05-02-2015, 08:59 AM
xx xx is online now
Mein Auto: F15 X5 and G01 X3
Excellent upgrade and info/pictures!! I didnt know the drive was right there (always thought it was hidden deep somewhere!) Maybe I'll have to try this mod too soon!!
X3 E83 (sold) | X5 E70 (sold) | X3 F25 (sold) | X5 F15 | X3 G01
Old 05-02-2015, 09:03 AM
Blame me but don't know what is NBT
Old 05-02-2015, 09:24 AM
Mein Auto: V70R
NBT is CIC's successor.
Old 05-02-2015, 10:02 AM
As long as they use regular 2.5" HDD you can do the upgrade
From quick research it shows that they use Toshiba 200GB Model MK2060GSC which is SATA interface /you still have to take it out and check it before you order SSD/
Once you confirm the interface and the size you most likely have to get 250GB SATA SSD
Old 05-02-2015, 11:24 AM
lanbrown lanbrown is offline
Mein Auto: xDrive 50i
Hmm, I'm wonder if you could use an mSATA SSD drive and then a mSATA to PATA 2.5" converter. mSATA drives are cheaper and faster and the converter would make it interface compatible. 128GB mSATA is less then $70 for a name brand, the converter not a name brand but under $10.
Old 05-02-2015, 11:28 AM
Oh, since the system uses QNX, I'd expect it to use the QNX4 filesystem.
Old 05-02-2015, 11:53 AM
AutoUnion's Avatar
AutoUnion AutoUnion is offline
Mein Auto: Deutsch Automobil
What a fantastic upgrade! I can't believe BMW was using 4200 rpm hard drive.
Old 05-02-2015, 12:20 PM
Almost all of the HDD based systems use the 4200 RPM drive. So BMW is not alone here. There are a few reasons and in no particular order
1) Cheaper
2) Reliability
3) Vibration handling
The drives used are designed to be used where there are more vibration than say a laptop sitting on a desk. Part of making them work in environment is slower rotational speed. Faster just means more problems.
Could manufacturers of used a 7200 RPM drive? Sure, but the warranty would have been voided as the drive was used in a non-approved way.
Old 05-02-2015, 12:21 PM
JoeSixspeed JoeSixspeed is offline
Mein Auto: none
True that!
Wonder what would be their explanation, may be the gyroscopic effects of the spinning disk platters on driving dynamics
Old 05-02-2015, 12:30 PM
Longhorn90 Longhorn90 is offline
Mein Auto: 2011 BMW X5 50i (RIP)
Awesome. I swapped out HD's in a couple Macs with SSD drives and it was a huge speed improvement, so makes sense IDrive would be more snappy.
Wonder if that'd void warranty - original and/or extended - for any related electronic or navigational systems that interact with IDrive?
___________________________
2011 BMW X5 50i (RIP...rear ended & totaled 2015)
2010 Honda Accord Crosstour EX-L V6 AWD
2014 Toyota Sienna Ltd Premium AWD
2015 Toyota Sienna Ltd Premium AWD
(detect a pattern....we like AWD)
Old 05-02-2015, 12:34 PM
They would need to prove that the alteration caused the failure. The screen failing has nothing to do with the drive being replaced unless you put it back together wrong. Just never admit you replaced the drive, the previous owner could have done it.
Old 05-02-2015, 12:38 PM
mkal mkal is offline
Mein Auto: E70 X5
This is great, thank you so much for documenting it and sharing!
Old 05-03-2015, 07:23 AM
Make sure you enable the TRIM support on Macs because when using non Apple SSD the Mac OS X cannot recognize the hardware and turns this option is off. If you don't enable it in 4-5 months the drive will become very slow and will eventually stop working
Old 05-03-2015, 02:12 PM
kakalika's Avatar
kakalika kakalika is offline
Mein Auto: 12 X5 d, 08 535, 02 530i
Awesome upgrade
Run flat tires? Nein Danke!
Old 05-03-2015, 03:29 PM
BMWOO7's Avatar
BMWOO7 BMWOO7 is offline
BMW CCA #505303
Mein Auto: '15 650 '13 X5 '13 Raptor
This is awesome and you did an outstanding job of #1 Thinking of doing this, and #2 Doing it and documenting it the way you did.
Obviously you need to copy the data from the existing drive and then load it to the new SSD drive.
Anything to watch out for here or potential 'gotchas' with this process. I only ask as I know with BMW most everything is coded to the car in some form or fashion.
With that said, one could actually perform a service to customers. Once you have a current drive file, I'm guessing you could pre-load it to SSD's and ship them out to customers with the simple instructions on how to change out the drive. -Just a thought................
Lastly, Thank you!
Old 05-03-2015, 03:32 PM
Since map data is in there and the FSC code is tied to a VIN, it may not work they way you think it will. Also, any settings you have set or destinations, etc. would all be in the cloned drive. So, it could cause more issues by doing that.
Old 05-03-2015, 03:35 PM
AutoUnion's Avatar
I remember swapping in a SSD in my circa-2010 MacBook Pro a few years ago. The difference was night and day.
It's nice to see SSDs go completely mainstream. They're basically in every mid to high-end laptop/ultrabook. Can't wait for prices to get lower. I remember spending $500 to spec a larger SSD on the retina Pro back in 2012.
Old 05-03-2015, 03:37 PM
AutoUnion's Avatar
As long as you do a complete drive clone (block by block), there shouldn't be any issues. The key is to find (and use) proper cloning software. If the cloning process stops at any point, it is best to wipe the SSD and start all over again.
For OS X, the best cloning software I've found is SuperDuper.
bmw, cic, diy, hdd, navigatio, sdd, upgrade, x5
