Rear Suspension question - Bimmerfest - BMW Forums
Old 12-04-2017, 07:22 AM
elb1999 elb1999 is offline
Mein Auto: 2011 X5
My wifes 2011 X5's rear suspension is literally dropping like a low rider at times when the car is turned off. There doesn't seem to be any pattern and it doesn't happen immediately. But occassionaly we come out to the car and the back end is low. We start the car get out out check and it's back where it should be. Anybody have any idea what's going on?
Old 12-04-2017, 09:52 AM
Yes, common issue. Your car is equipped with rear air suspension, which was part of the third row option but also available as stand alone option I believe. Anyway, that trick suspension includes airbags that maintain the height of the car regardless of load. They are known to leak over time. Replacements are $200 per side for the part I believe and labor is not tremendously difficult for a DIY guy. Arnott is an aftermarket supplier that many have used, they have a lifetime warranty on the airbags. Ignore the issue and the pump will be damaged due to having to work beyond standard specs.
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
Past:
2012 X5 Diesel
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
Old 12-04-2017, 01:14 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Ditto above...if looking at replacing the air shocks...check out Arnott's website (select for the model you have). You can also see how much the compressor is...so to avoid trashing it...stay on top of the issue to see if the problem are the air shocks...then replace ASAP if they are the culprit: https://www.arnottindustries.com/products/bmw
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 12-04-2017, 02:01 PM
CarterTG's Avatar
CarterTG CarterTG is online now
Mein Auto: 1996 1.9L BMW Z3 roadster
Arnott's site links to a removed video, but a YouTube search leads to this clip:
Doesn't appear to be a video specifically for the E70's compressor, tho'.
Carter
1996 Z3 roadster
2013 X3 xDrive28i
2013 X5 xDrive35i Premium
Old 12-04-2017, 04:17 PM
Dash Riprock Dash Riprock is offline
Mein Auto: 2012 X5 35d
FYI, BMW was going to charge me $3000 CDN for parts and labor. I ordered parts and had an Indy Mechanic complete the job for less then $600 CDN all in Parts and labour. I believe labour was basically $200'ish. Worth it to find a mechanic to complete.
Old 12-04-2017, 07:18 PM
ard ard is offline
Resident Curmudgeon
In case you are doubting it IS the airbags...
They crack/split/leak- however due to how they are compresed and loaded, and how they wiggle around, they may or may not loose air during any particular parking period.
Eventually one of two things will happen:
the leak will get bigger and every time you park overnight they will leak down
or
The leak will cause the pump to run all the time leading to a hard, total failure- they will stay down 100% of the time. $$$ instead of $
OEM is not what BMW sells
Old 12-05-2017, 03:19 PM
Badsmerf Badsmerf is offline
Mein Auto: 2010 X5 35d
Suncore also sells them. I need to replace mine soon to.
