New VANOS solenoids, lost "O" ring. Problem? - Bimmerfest - BMW Forums
Old 03-11-2018, 12:02 AM
plus1111 plus1111 is offline
Mein Auto: 2008 535xi
So I figured it was time for new VANOS solenoids on the 535xi. It's the N54, Being a klutz, I didn't see the old "O" ring stuck in the engine when I installed the new solenoids. I got a VANOS error when I started the car to test. I pulled the solenoids and can see with an Endoscope part of the "O" ring in the chamber. I grabbed it with long nosed pliers but it was stuck solid.
Now that I have removed the valve cover, the part of "O" ring has disappeared. Should I simply reassemble and pray?
Thanks in advance for any ideas.
Paul
Old 03-11-2018, 09:37 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530i; 2007 328 xit
That's a pretty small oring. It'll get torn apart and wash down to the oil pan, most likely. Too small to clog the oil intake. If you've examined the top end and it's gone (eg, not in the Vanos gearing etc), it's in the pan or a few pieces in the filter. I would't worry about it.
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 15+ Years
Old 03-11-2018, 09:31 PM
skull791 skull791 is offline
Mein Auto: E60
I have to agree with previous post. I been working on BMW for a long time, and small rubber ring like that will be just fine in there. If it gets torn a part then it may even was out with few oil changes.
Paul
