Squealing brakes - Bimmerfest - BMW Forums
Old 09-17-2018, 05:37 PM
Dash Riprock Dash Riprock is offline
Mein Auto: 2012 X5 35d
Squealing brakes
I changed my front pads and rotors about 15,000 miles ago and it appears the brakes only squeal when the weather gets cold (ie below freezing temp). The squealing happens in the last few seconds as you come to a stop. Very annoying for me and the people that ride with me. Rotors and pads were from BMW.
Wondering if others have had this issue previously and if they were able to rectify it.
Thank you.
Old 09-17-2018, 05:41 PM
edycol edycol is offline
Mein Auto: 328i xDrive 6MT
Thank you.
Was everything greased up?
Sent from my iPhone using Tapatalk
Old 09-17-2018, 05:43 PM
twh twh is offline
Mein Auto: '06 530xi 6sp
Did you put the hi-temp disc brake grease where indicated?
Did you properly replace the springs?
Old 09-17-2018, 05:49 PM
I did not replace them myself, I had an Indy mechanic I have worked with for more then 2 decades do it, I could ask him. Can you add the high temp grease after the fact? I have replaced pads and rotors on my other vehicles and never used high temp grease, but the BMW I leave to people more expert then myself.
Old 09-17-2018, 07:21 PM
twh twh is offline
Also supposed to use the grease.
For my X5, this is the procedure:
https://www.newtis.info/tisv2/a/en/e...brakes/Gb5mwSu
Yours will be the same probably, but pull up your TIS to be sure.
Old 09-18-2018, 05:26 AM
1bad540's Avatar
1bad540 1bad540 is offline
Mein Auto: E65 750i Sport,C5 z51 e46
Thanks for posting the Tis,
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,20"s63rims
e70 3.5 aw.mtec,20" 214 whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
w222 S550 amg, dia white
Old 09-18-2018, 10:14 AM
It is actually easier then on some cheap cars to do brakes.
brakes, rotors, squealing
