Replaced Mechatronic Sleeve - no communication now - Page 2 - Bimmerfest - BMW Forums
Old 12-19-2018, 12:42 PM
bimmer7410 bimmer7410 is offline
Mein Auto: 2003 540i
Originally Posted by plus1111 View Post
The valve body is reinstalled. The sleeve actually went in - I managed to get a finger in it to guide the key. The connector screwed on and so far, the car is happy. I still need to torque the pan bolts and do the refill. I stop and jiggle the harness from time to time, then check for errors before each step. I think it might work!
I am breathing a sigh of relief along with you dude.
Old 12-19-2018, 12:47 PM
F1mugen F1mugen is offline
Mein Auto:
Was the issue resolved by correctly placing the mechatronic sleeve in and filling thr fluid back up? As i am going to open up my transmission again over the weekend for the 3rd time and want as much info to look out for whilst im under there.
BMW 525d Msport 2009 LCI Stage 1
Old 12-19-2018, 01:01 PM
plus1111 plus1111 is offline
Mein Auto: 2008 535xi
We went for a test drive over the lunch hour today. I am not sure I got the relearn properly set but it drives differently, nicely. Gears engage promptly, shifts are firm. It seemed to wait a bit long to get into 6th but I really need to do a proper retraining.trip to be sure.
Old 12-23-2018, 07:32 AM
Mein Auto:
Sorted my issue.
It was the EGS connector flooded with oil as the sleeve wasnt on properly and pin no 3 was bent and i broke it whilst trying to fix it.
Old 12-23-2018, 10:02 AM
F1mugen. I am sorry to hear the pin broke. I feel very fortunate that I didn't break mine. I've made quite a few short trips and mine seems good. It still holds in 5th longer than I think it should before hitting 6th. No slipping or anything else weird and first engagement from park is fast.
That connector is a fairly common industrial part. It is possible to replace the pins from what I have been told. Finds parts might be rough but finding someone with access and tools to fix it might be easier. My brother was a maintenance tech for years in a factory and said he's replaced pins a few times in that type of connector.
Old 12-23-2018, 10:32 AM
Mein Auto:
The pin that was broken wasnt needed as not all pins are connected thats why i left it.
Quiet a few pins arnt connected on the connector side
Old 12-23-2018, 10:42 AM
Cool! Glad to hear!
Old 12-23-2018, 10:54 AM
Mein Auto:
Cool! Glad to hear!
Thanks, was a relief as i didnt fancy forking out for a new transmission/mechatronic unit.
Old 12-26-2018, 10:06 AM
Well, everything is back together and I've driven a few hundred miles. Everything shifts as it should and is nice and solid. One weird issue tho - Sometimes I get a warning that the transmission can be shifted without pressing the brake. The error code is 4E87 - EGS solenoid calve 4 (shift lock). I suspect my mechatrinics connector is still not quite seated right since the gap from the locking ring to the case looks larger than it should be. I might order another mechatronics sleeve to experiment with.
It looks like I need to repair the front propeller shaft (drive shaft) too. After hanging down for a couple of weeks it took a lot of force to get it to move at the attached end. Pretty sure the bearings have gone dry or have just failed. Oh well, just adventures of a 12 year old car I suppose.
