RED Screen of death - Bimmerfest - BMW Forums
Old 07-11-2019, 08:42 AM
noelskii noelskii is offline
Mein Auto: E70
RED Screen of death
Hi all!
I have the CCC system ( i think..OLD screen no navi maybe 6.5"?)...but I have the AvinUSA 11.25" screen on it...
It turned all red out of nowhere 2 weeks ago - I've searched and everyone says to hold down the volume knob to reset it, but this never worked for me. It never reset nor fix anything.
The android side of this AvinUSA display is perfectly fine. It is only RED when I go to the original iDrive menu...
HELP!
2007 X5 3.0 Si
Old 07-15-2019, 10:12 AM
Mein Auto: E70
Anyone?
2007 X5 3.0 Si
Old 07-18-2019, 12:52 PM
Mein Auto: E70
Help!
Help
2007 X5 3.0 Si
Old 07-18-2019, 04:31 PM
FredoinSF FredoinSF is online now
I think the fact you have avin throws a curve ball.
There is a audio / entertainment system subforum. Cross post there.
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
Past:
2012 X5 Diesel
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
Old 07-18-2019, 05:54 PM
BabyUnicornTaco BabyUnicornTaco is online now
Mein Auto: 2008 X5 4.8i E70 Sport
Why not contact Avin? I bet their customer service will troubleshoot with you.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 07-19-2019, 11:55 AM
Mein Auto: E70
I contacted AvinUSA and they told me it looks like a factory issue. This is how I found out about this "red screen of death" stuff.
I just can't seem to do this "reboot" that everyone is able to do with their iDrive. Hoping not to actually have to put my stock radio back on.
Was hoping of just replacing a damaged wire harness or something.
2007 X5 3.0 Si
Old 07-19-2019, 12:01 PM
Mein Auto: E70
Picture attached
2007 X5 3.0 Si
Old 07-19-2019, 12:55 PM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
Maybe try flashing update for ccc/mask. I forget which one you would have
Old 07-20-2019, 12:05 AM
What do you mean by factory issue? The BMW factory or the Avin factory.
Either way itís not a factory issue, but Iím thinking itís the display itself that pooped the sheets.
Also, since you have the Avin system, the CCC reboot method wonít apply unless they programmed the same function. Youíre no longer dealing with standard bmw stuff.
Sent from my iPad using Bimmerfest
Current:
2018 540ix
2013 Cooper S
2007 650i - 6 speed
Past:
2012 X5 Diesel
2006 330i - 6 speed
Old 07-22-2019, 07:03 PM
cvgtpc1 cvgtpc1 is offline
Mein Auto: 2008 E60, 2008 E70
Originally Posted by noelskii View Post
Picture attached
I have an AVIN and whenever it does goofy sh** I disconnect, reconnect, and it comes back to life. Fortunately its quick and easy to do. Have you tried that?
cvgtpc1
- 08 E60 LCI 528i - VIN: C112981, Engine: N52K, MONACOBLAU METALLIC, Prod.date: 2008-05-15
- 08 E70 X5 3.0Si - VIN: L008866, Engine: N52K, TITANSILBER METALLIC, Prod.date: 2007-12-22
RIP 04/23/18
- 02 E39 525i
Old 07-22-2019, 10:42 PM
Absentmathis Absentmathis is offline
Mein Auto: E70
Picture attached
Yeah I've got one as well and they're total POS's. This is a factory video feed issue. May be related to the connection to the Avin and I've had to disconnect and reconnect mine countless times but never seen that red screen. That might solve it or the (also POS) factory unit may have crapped out.
Old 07-23-2019, 06:41 PM
Hack213 Hack213 is offline
Mein Auto: E70 4.8
Did u fix it ?
Old 08-12-2019, 06:18 PM
Mein Auto: E70
Originally Posted by Hack213 View Post
Did u fix it ?
It's still red. The android side of things is fine so I usually keep it on there before I turn off the car so that when it starts up again, it goes straight to Android side.
Where do you guys "unplug" and reconnect?
2007 X5 3.0 Si
Old 11-22-2019, 06:37 PM
Mein Auto: E70
Any ideas? the iDrive is fully functional, I can still see everything. It looks like when you disconnect one of the RGB component jacks on the tv..RED
2007 X5 3.0 Si
Old 12-03-2019, 07:37 PM
Mein Auto: E70
Anyone know where the other side of PART #1 connects to? I know one side goes to the back of the monitor, but can't seem to trace the other end of it....
https://www.realoem.com/bmw/enUS/sho...diagId=61_2569
2007 X5 3.0 Si
Old 12-03-2019, 08:01 PM
The other end goes to the back of the radio/mask/champ.
cvgtpc1
RIP 04/23/18
- 02 E39 525i
Old 12-05-2019, 04:14 PM
Mein Auto: E70
Which exactly is the radio/mask/champ? Is that the unit with the volume knob?
I ordered the new wire, hopefully it fixes the red screen on the factory side...
Nothing wrong with my Avin radio at all - never had issues with the android side of things.
2007 X5 3.0 Si
Old 12-05-2019, 04:15 PM
Mein Auto: E70
Nothing wrong with my Avin radio at all - never had issues with the android side of things. I've tried unplugging and reconnecting the wires and it doesn't fix the red screen issue.
2007 X5 3.0 Si
Old 12-06-2019, 07:55 AM
Yes, the unit with the volume knob. The one time I had the red screen fortunately reseating that cable fixed it.
My mask was flaky, inputs would change erratically and volume knob was wobbly. Replaced on ebay for $200. But now need to code and don't have icom to do it with. Tool32 wouldn't do it.
cvgtpc1
RIP 04/23/18
- 02 E39 525i
Old 12-13-2019, 08:21 AM
Mein Auto: E70
Installed the new wire and it's still red SMH!
2007 X5 3.0 Si
Old 12-14-2019, 09:44 AM
Dash Riprock Dash Riprock is offline
Mein Auto: 2012 X5 35d
I have had the red screen before and I luckily the following morning it started working again. I thought I was for sure going to have to fork out $3,000 to fix it.
Sorry I cant be of help, Good luck!
Old 12-15-2019, 08:58 PM
Mein Auto: E70
hmm... wonder what else it could be...
2007 X5 3.0 Si
