How much oil is too much in your turbo? - Bimmerfest - BMW Forums
Old 03-13-2019, 02:49 PM
Dash Riprock Dash Riprock is offline
Mein Auto: 2012 X5 35d
So I took my 2012 35d (95,000 miles) into a new indy mechanic to get the thermostat replaced and figure out why I was getting oil leaking on passenger side of motor. He sent me the following pictures and told me my the following pipe was cracked, but wasn't sure if my turbo was ruined, he indicated there was oil in it. I was in a meeting so the conversation was not detailed. He was going to make some calls and get back to me with an estimate. I have not seen any performance issues in the last while and I have no idea what I am looking at, but I did not get a good feeling from our phone call.
Has anyone seem something similar?
Thanks for your help.
Name:	bmw engine.jpeg
ID:	843765   Click image for larger version
Name:	cracked engine pipe.JPEG
Old 03-13-2019, 06:25 PM
PeterO PeterO is offline
Mein Auto: X6M, '90 E30 vert
First pic looks like a gunky engine and the second could be a hairline crack in the turbo. Its pretty clean though so I would wonder why he thinks its from that. Might just be a superficial thing too, hard to tell. There is going to be some oil in there from the CCV system (Does the diesel have this?). Its usually pretty clear if the turbo is bad as it will not spool at all or blow a ton of black smoke.
IMO it should be pretty obvious if the turbo is leaking oil externally. If thats the case at the very least the fittings need to be fixed.
Old 03-15-2019, 01:15 PM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
Its on the turbo fresh air side which isn't extremely hot. Was there oil coming out of this crack?
I'd just clean it and put a later of jb weld on to of it as a coating. It could be just a weird mark left by a bad casting where dirt gets stuck inside but the jb weld should work fine for many years.
Old 03-18-2019, 03:41 PM
I could not tell you if oil was coming out from the crack as I cleaned that side of the engine before I took it to the shop, we were trying to diagnose if/where the turbo oil lines were leaking.
Similar Threads
Oil Change Issue bobX-1 X1 E84 (2011 - 2015) 8 12-02-2018 11:19 PM
2013 740i I have to add oil when I drove over mountains Fonxprt 7 Series - F01 / F02 / F03 / F04 (2008 - 2015) 6 06-14-2018 08:40 PM
Oil use 2014 535i DProffitt F10 / F11 (2011 - 2016) 4 04-14-2018 09:51 AM
Oil change Guest84 Off-Topic 21 08-12-2014 03:30 PM
DIY - 528i OIL Change (E39) 6 cyl GOKOOLJAPAN 5 Series DIY 56 12-18-2009 11:08 AM
