Heater Diagrams showing air flow and flaps? - Bimmerfest - BMW Forums
Old 11-15-2019, 03:40 PM
plus1111 plus1111 is offline
Mein Auto: 2008 535xi
I am fighting with weird heat issues and had weird A/C issues last summer. All the basics check out. I have decent air flow, the auto functions move air up and down as usual but the air is cold or lukewarm.
I have replaced the heater water valve and flushed the cores to confirm good coolant flow in both sides. After a drive last night the drivers side blew warm but the passenger side was still cold. When I felt the heater hoses all three burned my hand.
The radiator hoses were hot too. I suspect maybe something in the heater assembly is wonky but it would help a lot to know what goes on in there.
HELP!
And THANKS!
Hobby mechanic doing my own work for 50 years or so.
We have a 2006 530xi Touring and a 2008 535xi sedan.
I can't really remember the last time I took a car to a repair service.
Old 11-15-2019, 04:48 PM
Ridin'Dirty's Avatar
Ridin'Dirty Ridin'Dirty is online now
'17 X1 - Rooster Cruisin'
Mein Auto: '93 "Beemer" R100r
I can't find specifically what you are looking for but I can get you to the section on "newTIS.info" when there are several articles that may help:
https://www.newtis.info/tisv2/a/en/e...ater-controls/
It's not really yours until you void the warranty.
Old 11-15-2019, 08:00 PM
Thanks. I don't easily find things in newTis. I appreciate it.
Old 11-15-2019, 11:03 PM
MysticRob MysticRob is offline
Mein Auto: E61 535xi Deep Sea Blue
Are your iDrive hvac settings set to cold?
My iDrive settings greatly affect how hot or cold the air blows, irrespective of how I adjust the temp dials for each side.
2008 535xi E61 Touring Wagon / 110k Miles / Deep Sea Blue Exterior / Natural Brown Leather Interior / MHD Stage 1 91 Octane Tune / xHP Stage 1 Transmission Tune / xHP xDelete
Old 11-16-2019, 10:54 AM
Thanks. iDrive and I have had many chats. All heat settings are at max. The 2008 car has temp settings for the automatic cycle and manual. This 2006 only has a temp setting for the manual side. I shall continue to investigate.
Old 11-17-2019, 01:56 PM
I started cold today. I set Calry to monitor as many temperatures as I could fit. Then I attached an electronic temp probe to the top radiator hose and another to a heater inlet hose.
The radiator hose got hot quickly and the heater hose stayed several degrees cooler but both began rising almost as soon as I started driving.
I conclude thet the thermostat is stuck wide open. I guess I'll replace it.
Thanks for all the great ideas, folks!
