A/C Compressor - clutch or not? - Bimmerfest - BMW Forums
Old 01-27-2020, 06:09 PM
plus1111 plus1111 is offline
Mein Auto: 2008 535xi
E61, 2006 530xi. I suddenly have a dry bearing noise that I've tracked down to the compressor. RealOEM shows 2 possible compressors, one with a clutch and one without. I'd like to know which one I need before I take the old one off.
I thought all E60/61 used the variable compressor with no clutch, now I am confused. I've never heard the usual clack or a clutch in action and when I was tracking down a weak cooling issue the pressures stayed pretty constant so I was sure it was the variable compressor. Any thoughts?
Hobby mechanic doing my own work for 50 years or so.
We have a 2006 530xi Touring and a 2008 535xi sedan.
I can't really remember the last time I took a car to a repair service.
Old 01-27-2020, 06:32 PM
BabyUnicornTaco BabyUnicornTaco is online now
Mein Auto: 2008 X5 4.8i E70 Sport
Realoem.com should tell you what compressor you have if it is original.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 01-27-2020, 06:36 PM
That's my issue. It lists two. I don't see any notes of before/after or the like. I'll go study it some more tho.
Old 01-27-2020, 07:08 PM
twh twh is online now
Mein Auto: '06 530xi 6sp
I have a 2006 530xi. This is the compressor installed..."SEU17C". My compressor is making more noise the past few years, but still holding out so far.
Old 01-27-2020, 07:11 PM
This began suddenly, right after I replaced the water pump. It has no wobble or looseness but sounds awful (to me, at least.)
Thanks.
Old 01-27-2020, 07:58 PM
Only thing I can think of is you fouled the serpentine belt with coolant and that's making noise on the pulley. Every time I work on the cooling system and a lot of coolant is released, I hose down the front of the engine liberally with the garden hose and also replace the belt. Can't be too careful on the N52 engine.
Old 01-28-2020, 03:51 AM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '15 435i '10 535i '08 X5
Something interfering with belt grip makes more sense than a bad compressor. Post a photo of compressor. Clutch and clutchless compressors are noticeably different. On a compressor with clutch there is a small (~0.005") gap between the clutch plate and the pulley. You should be able to turn the plate in front of the pulley and the pulley will remain stationary. Can't do this on clutchless unit.
Old 01-28-2020, 05:31 AM
I wish it was that simple. I removed the belt and spun each rotating component. The only one that makes noise is the compressor.
I will go house it down, maybe even use some cleaner on it, just in case, tho.
Old 01-28-2020, 05:48 AM
BMW CCA 69606
If you can spin compressor pulley with belt off, then compressor has a clutch. Regardless of whether AC is clutchless or not, the pulley bearing is replaceable without having to replace the compressor. Parts are on ebay. You can get the bearing from a local supply house also.
Old 01-28-2020, 08:28 AM
That is what I was hoping to hear! Thanks pshovest!
Old 01-28-2020, 08:47 AM
dharmabmw dharmabmw is offline
Mein Auto: 2006 530Xi
Don't delay the repair. The bearing will fail catastrophicaly. The belt can wrap around the harmonic balancer with even worse results.
2006 E61 MT
2010 E91 MT
Old 01-28-2020, 08:50 AM
That is what worries me. Thanks.
Old 01-28-2020, 11:11 AM
wcr3d wcr3d is online now
Mein Auto: 2013 535iX M Sport
When using realoem input the last 7 digits of your VIN to get results specific to that car.
Old 01-28-2020, 12:18 PM
SunglassesGuy SunglassesGuy is offline
Mein Auto:
I have read variable, didn't realize this either. You can hear the clutch engaging - on older cars anyway. Have an assistant turn your a/c on/off an listen for it to engage.
Another thing you might try is to look up each part number and get photos, maybe you can tell from the photos.
Jim from Austin
2004 BMW E60, N62, GA6HP26Z, Dynamic Drive, Sport Pak, Logic 7, Bilstein B8's, Ti Silver
2009 BMW E63 M6, Sapphire Black
1990 Pontiac Firebird Formula, T-Tops, 305 TPI, Maui Blue
Old 01-28-2020, 12:25 PM
My next step is to raise the car and have a closer look. There has to be some identification on it somewhere.
Old 01-28-2020, 12:27 PM
By the way, there is another thread here discussing the correct belt to use to bypass the compressor. It looks like that worked so I have an option if I can't fix it quickly.
Good thing fixing cars is a hobby of mine tho.
Old 01-28-2020, 02:17 PM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530i; 2007 328 xit
The 7SEU denso compressor used on the N52 is clutchless. Below is a YouTube video of replacing the pulley and bearing on the bench, though on the car is done quite often.. There are replacement kits available on eBay. They usually have the bearing, the pulley, and the rubber inserts. Url at bottom of post. Cost is around $50. Good luck.
https://www.ebay.com/itm/A-C-Compres....c100889.m5204
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 15+ Years
Old 01-28-2020, 03:18 PM
Thanks banglenot. This is exactly what I needed.
Old 01-28-2020, 03:54 PM
Iím in the same boat on a different BMW model. I have a similar thread. My pulley snapped away from the bearing. Iíll be using some of these videos to help me as well. My pulley appears to only need a new pulley with bearing installed from eBay or some other place. Iíll be checking your thread as well. Iím leaving my compressor installed while I do it. My ac belt fell off and cycled through the harmonic balancer somehow and can out intact. I was lucky to not suffer other issues.
Old 01-28-2020, 05:59 PM
BMW CCA 69606
The N52 in my X5 has a clutch.
Old 01-28-2020, 06:26 PM
I am fortunate to have another car to use. I will get under it soon for a close look and a model tag.
Old 01-28-2020, 06:49 PM
BMW CCA 69606
Post a picture of the front of the pulley. Use "Go Advanced" and "Manage Attachments". Compressors with clutch have an extra wire going to the coil behind the pulley
