Does my i3 have high speed charging? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW i > BMW i3 I01 (2014 - Current)
The BMW i3 and BMW i8 are the first two cars launch under BMW's new sub brand BMW i. The i3 is an all carbon fiber, all electric vehicle meant for urban mobility.
Old 02-02-2019, 09:14 AM
jferris1119 jferris1119 is offline
Mein Auto:
I just got a 2015 i3 Rex with 16000 miles. I have recharged at home with 110 volts.
Can I use the high speed recharging at my local EvGo charger?
Is it the second charge port with two prongs?
Old 02-02-2019, 09:18 AM
sc68z28 sc68z28 is offline
Mein Auto: 330e, X3 M40i, i3
Short answer is YES.
Old 02-02-2019, 09:33 AM
God-Follower's Avatar
God-Follower God-Follower is offline
Achtung! Hochspannung!
Mein Auto: 2018 i3, F10 535d
Yep! If your car has the two extra large pins at the bottom, you can DC Fast charge. In the USA it was standard on 2015 and newer.
Old 02-02-2019, 09:40 AM
Mein Auto:
Thanks to all. I'm off to get a quick charge.
Jeff
Old 02-02-2019, 08:28 PM
In some markets, there were three options on charging, so nomenclature can get a little messy.
The i3 has a device called the KLE that essentially doubles the ability to charge when using acv. Then, it also has the extra, optional in some MY and markets, that allows it to use a CCS (DC fast charging).
In the USA, we always got the KLE, so can recharge at the higher acv input levels. The earliest i3's sold here did not have the CCS (DC fast) charging capability as standard. IF you have it, below the upper connector, there's a second receptacle that has two pins.
Without the KLE, maximum charging rate is in the order of 3700W. WIth it, 7400W (although in some markets with 3-phase power, it's higher). The CCS input on the i3s so equipped is 50Kw. NOte, not all charging stations provide the max the i3 can use. Some have more, but won't hurt the i3, as they communicate to limit the output to what the i3 can handle.
Jim DeBruycker
Old 03-15-2019, 07:15 PM
BMWtechN63 BMWtechN63 is offline
Mein Auto: Not a BMW
Even with the turbocharger, at a 110v it will still take 15hrs or so to fully charge. Amazon sells a Juicebox charger that can run off 220v and it's about 4.5hr to fully charge. The car will only accept 7.4kw max charge so trying to go anything over 40amp charger is pointless. The only way you can charge more is with a DC fast charger.
Old 03-16-2019, 07:46 PM
The time to fully charge depends on more than one thing:
- the SOC when you start
- the battery and ambient temperature when you start
- the region where you bought your car...some have 3-phase inputs, most have single, and the maximum charging rate differs between the two
- whether you've selected the charge limiting in the menu
- the size of the EVSE...larger doesn't buy you anything unless the car can handle it, but won't hurt it. Note, newer vehicles may end up being able to use more, so having that capacity may futureproof your EVSE, at least in convenience, but will still work fine, but slower.
Jim DeBruycker
Old 05-24-2019, 02:02 PM
sipabit sipabit is offline
Mein Auto: 2016 BMW i3 REX
Just a warning though. Quick charging too often isn't healthy for the battery. Also, depending on where you live, it may not be any cheaper than gas.
A fanatic of all things electric. Ridables like electric ice chests and stand up scooters I adore. Drones like DJI, I root for. I'm a fan of both, but nothing beats my love for my 2016 i3 Rex with Deka World. Shhh, don't tell my wife.
Similar Threads
Low charging pressure -> FC 120308 / Long story / Drasta F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 1 06-02-2019 05:28 PM
Coolant light comes on in high speed Shamas007 X3 E83 (2004 - 2010) 7 10-03-2018 06:57 AM
MazdaSpeed 6 Official info from Dealer Optimus Prime General Automotive Forum 47 10-18-2004 04:07 PM
6 Speed Vs 5 Speed Memphis10 3 Series & 4 Series 47 09-11-2003 11:18 PM
Do those of you w/o high speed (cable modem, DSL, T-1, etc.) hts Off-Topic 4 12-24-2001 07:55 AM
