bmw i3 EDME broken - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW i > BMW i3 I01 (2014 - Current)
The BMW i3 and BMW i8 are the first two cars launch under BMW's new sub brand BMW i. The i3 is an all carbon fiber, all electric vehicle meant for urban mobility.
Old 02-20-2019, 05:33 AM
nathierkh nathierkh is offline
Mein Auto:
bmw i3 EDME broken
i had small accident and front left fender damaged my car went off and display ready all the time if found the basic control unit under the fender is broken then i bought a second hand one have the same number of the broken one and the car still not working....so what can i do please
Old 02-26-2019, 11:08 AM
God-Follower's Avatar
God-Follower God-Follower is offline
Achtung! Hochspannung!
Mein Auto: 2018 i3, F10 535d
The new control unit will need programmed to the vehicle before it will work. You will need either E-Sys or ISTA Next to program the vehicle.
Old 02-26-2019, 11:25 AM
Mein Auto:
I went to an expert and he try to reprogram it but he said that i have to buy brand new unit because the used one cant be reprogram
Old 02-26-2019, 01:26 PM
There are varying levels of experts in the field of working on BMWs. I can't make any promises, but there have been other posts in this forum looking for i3/i8 immobilizer workarounds due to replacing modules with used ones. I helped this guy out a bit with his i8, but never heard if he found a final solution:
https://www.bimmerfest.com/forums/sh....php?t=1276122
It should at least get you going in the right direction on what to look for. I would probably start with pulling up the module in E-Sys and doing a program/code on it with your vehicle FA loaded, see if that is all that is required. If not, then you will have to start tinkering with INPA and/or Tools32 to see if you can find an operation to relearn the EWS to the new module. I don't have a step by step guide for you, nor can I promise it is even possible. But to my knowledge, that will be your best bet
Looks like you already posted part of this over to the coding subforum as well.
Old 02-27-2019, 04:56 AM
Mein Auto:
Thank you very much iwill try
Old 03-15-2019, 07:12 PM
BMWtechN63 BMWtechN63 is offline
Mein Auto: Not a BMW
You should program the vehicle at a BMW facility. When programming, you have to bring down the High-Voltage system or you can ruin things. Do not try and work with the HV system as you are not qualified to do so.
edme basic control unit
Similar Threads
1998 M3 = 540i = 740i = 20K rumratt General BMW Questions 36 01-12-2007 06:26 PM
The History of the BMW 5 Series WAM 5 Series 5 08-17-2006 08:46 PM
THE NEW BMW 1 SERIES with Photos (BMW Press Release) pixA4 E82 / E87 / E88 / F20 1 Series (2008 - 2014) 27 09-29-2004 06:50 PM
A Hit Parade for BMW? (Must-read BusinessWeek Article) Spiderm0n General BMW Questions 10 09-14-2002 11:18 AM
