i3 coding - Page 14 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW i > BMW i3 I01 (2014 - Current)
The BMW i3 and BMW i8 are the first two cars launch under BMW's new sub brand BMW i. The i3 is an all carbon fiber, all electric vehicle meant for urban mobility.
Old 07-23-2019, 11:57 AM
God-Follower's Avatar
God-Follower God-Follower is offline
Achtung! Hochspannung!
Mein Auto: 2018 i3, F10 535d
Originally Posted by Christopheri3 View Post
Need some help from any brainy coders out there.
I have changed the steering wheel on my 2017 REX, and the steering buttons are not working. I have tried in Bimmercode 3140 PfLSteeringWheel. and tried F15/F45/F56/F16 and nicht_aktiv. it was set to I01. still not working??? am I not doing it right?
Thanks in advance
That looks like a G-car steering wheel, haven't seen one retrofitted to i3 yet. I have seen i8 wheels put in i3 successfully however.
Old 07-23-2019, 12:11 PM
krumian krumian is offline
Mein Auto: BMW
You are right but this has the large screen. HU-NBT with VIN V505730. So I'm stumped.
Old 07-23-2019, 12:19 PM
You are sure the video file you are trying to play has the video encoded in a supported format?
Old 07-23-2019, 01:13 PM
Mein Auto: BMW
Yes, same MP4 videos from the the same USB stick I use in other cars.
Old 07-23-2019, 03:15 PM
Mein Auto: BMW
The only thing I can think of is that this car had been coded previously and maybe some things were corrupted. I'll VO code the HU-NBT from fresh and reset everything. Hopefully that'll clear things up.
Old 07-28-2019, 07:58 PM
Deepblue75 Deepblue75 is offline
Mein Auto: i3 / RAM 1500
Hi all, new to this forum.
Wow a ton of information here - very informative and helpful people too.
So i recently - like on Friday became a used 2017/2018 i3 REx owner. I have a VIN ending in VC34662 and using other internet resources I have determined that I can code my i3 to enable enhanced Bluetooth functions.
I have the paid version of the BimmerCode app and have used it to enable other functions / features successfully however, I cannot find a definitive guide for Enhanced Bluetooth (EBT). Is there a guide that someone has or has someone done this before using the BimmerCode app? I am using a VGate iCar Pro 4 BLE / Bluetooth 4.0 ODBII for connectivity. From my understanding I would need to use Expert mode in the app - but am not totally sure which ECU's to configure.
Most of the guides are for non-i series units
I am also open to coding it using the USB option and if anyone has the package for the USB option, please PM me ASAP!
Any help / guidance is appreciated. PM is welcome.
Old 08-03-2019, 06:33 PM
problem solved. Seems like it can be done using BimmerCode App using expert mode. Problem was that the Bluetooth version o my Android phone was too high.
I enabled a downgraded version and everything is working fine.
Old 08-05-2019, 03:36 AM
darkrider darkrider is offline
Mein Auto: x3 2005
hello everyone!
I am now the proud owner of 2x BMW I3 60 ah for my wife and I. One with Rex, the other without.
I have 2 climate control consoles
1) the first without many options and no LCD display on the temperature knob
2) the second with full options, including LCD display on the temperature knob
I purchased an advanced console on ebay, and would like to replace my wife's console with this one.
the installation went well, I followed the official instructions available under >> https://www.newtis.info/tisv2/a/en/i...ols/1VnXYEoUng
All went ok, but the car doesn't recognize the new console, so many features are disabled
Do you know how to "code" the car to accept the new console? can BimmerCode App help in this context?
thanks and regards
Alex
Old 08-06-2019, 03:48 AM
xavier188 xavier188 is offline
Mein Auto: i3 (I03) Rex
hi
I'm interested in explaining the transformation into 6NS - Enhanced Bluetooth (EBT) with Bimmercode.
regards
i3 94Ah Rex
Old 08-21-2019, 03:49 AM
chud666 chud666 is offline
Mein Auto: x1
I am having issues coding a 2019 REX i3. I am using E-Sys 3.30.1 with Launcher Pro 2.8.1.155. PSDZDATA version is 4.18.33.
I have used the below procedure on a Windows 10 64-bit physical system with no previous versions of coding software installed. I have also tried it via a virtual machine. Both methods result in the same problem.
I run the launcher and get into E-Sys without any problem. When I connect, I am have two versions of the I001 target. I am not taking about the DIRECT one, but an entirely separate option. One is I001_19_03_552_V_004_001_000 and the other is I001_19_07_539_V_004_001_000. Both of them have DIRECT options with the same version.
I can connect using either version. I then read and activate the FA, then push the “Read (ECU)” button, which then populates the SVT window. I can select a green checked item then select “Read Coding Data” from the context menu. That changes the selected item into a folder, which I expand, select the item within it then select “Edit FDL” from the context menu. That switches me to the FDL Editor window
I can then navigate down to the item I want to edit. Once I get to it, I see the item and its value, but it is not editable (“greyed out”). I tried several different modules and multiple values, but they are always not editable.
I attached photos of what I am seeing in E-SYS.
I’d appreciate some advice on how I can get past this issue.
Name:	EDIT FDL 1.jpg
ID:	861781   Click image for larger version
Name:	EDIT FDL 2.jpg
ID:	861783   Click image for larger version
Name:	Grey Options.jpg
ID:	861785   Click image for larger version
Name:	i3 connecion options.jpg
Old 08-21-2019, 05:33 AM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
You are in the wrong location. Expand correct folder and you should be able to modify.
Old 08-21-2019, 09:52 AM
Mein Auto: x1
Can you elaborate? It's not just that option, but every one that I've tried in multiple modules.
Old 08-22-2019, 03:01 AM
Mein Auto: x1
Thank you very much, Almaretto. I initially didn't see the photo on your reply to my post. Once I did, I immediately realized what I was doing wrong. A definite case of user error on my part.
Old 08-22-2019, 11:39 PM
Almaretto's Avatar
Super Moderator
