How tolerate the ABS can be for different tire size - Bimmerfest - BMW Forums
Old 06-29-2019, 10:07 PM
Dalplex's Avatar
Dalplex Dalplex is offline
Mein Auto: 08 Smart Fortwo
Hello,
Will ABS chime in if the front is 2.2% larger then rear?
Or would CC not engage once above certain speed?
Thanks for your advise
06 750 Li, Clattering noise, suspect piston 2 hits head due to spun bearing.
03 760 Li,
coolant leak from back plate.
Random misfire codes.
Old 06-29-2019, 10:19 PM
Target Target is offline
Mein Auto: BMW E65 745i
I have a staggered setup on mine, with 245/45-R18 in the front and 255/55-R18 in the back. That's only a difference of 1,33%, but it doesn't cause any problems.
My first staggered setup on the car was with more than 5% difference, and that caused some errors (can't remember which, sorry) and it also caused the autopark feature to stop working.
Out of interest; why would you ever have larger wheels in the front than the rear?
Old 06-30-2019, 04:26 AM
Dalplex's Avatar
Thanks.
The original front is 245/35/21 and rear is 285/30/21. The front just not right as it looks stretch too much.
I have a set of 265/35/21 from Audi. Or I can buy a pair of 275/30/21 but may be too hard to mount.
03 760 Li,
Old 07-01-2019, 11:41 AM
JayR04's Avatar
JayR04 JayR04 is offline
Mein Auto: F02
If the difference in height is within 3% you should be fine
2018 Lexus LS500 (current)
1984 Chevy Monte Carlo SS (current)
2018 BMW X6
2016 Chevy Corvette
2012 BMW 750Li
2014 Lexus GS350
2013 Lexus ES350
2010 Nissan Maxima
2009 Dodge Challenger R/T
2006 Dodge Charger SXT
1990 BMW 735i
Old 07-09-2019, 11:10 AM
Dabizness24 Dabizness24 is offline
Mein Auto:
I just had this problem with my 2006 760li. I had put a staggered 20 inch set on my car with 245/35/20 in the front and 275/40/20 in the rear. My abs, parking light, and traction control fault light all came on within a block of getting the tires mounted.. after doing research it appeared that the abs speed sensors were likely reading the rotation of the front and rear tires at two different speeds due to the front tires being smaller they rotate at a faster rate. I decided to change my front tires to 245/40/20, my problem went away.
Old 08-04-2019, 02:32 PM
Dalplex's Avatar
Update:
Replaced the front 245/35/r21 with 265/35/r21 with much better appreance.
No abs problem yet.
03 760 Li,
