4E25 Electronic Pressure Control Valve (converter clutch) - Bimmerfest - BMW Forums
Old 04-23-2018, 07:42 AM
BabyUnicornTaco BabyUnicornTaco is online now
Mein Auto: 2008 X5 4.8i E70 Sport
ID:	790888Click image for larger version
Anyone have experience with these fault codes? What am I looking at here? Car ran fine yesterday. Parked overnight and this morning will not come out of park with a transmission malfunction message. My BMW scanner read the fault codes in the pictures.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 04-23-2018, 10:02 AM
smassey321 smassey321 is offline
Mein Auto: 09 X5d, 06 325i, 06 330i
Check your battery voltage first. Low voltage can throw odd errors. If you do have a bad pressure converter, you can purchase an entire set for $350. Replacement is not much more effort than a fluid/filter replacement.
Old 04-23-2018, 10:06 AM
The pressure regulators are the yellow, black and green things shown at the end of this video.
Old 04-23-2018, 10:10 AM
A glimpse of good news. I already had my car towed to my Indy. Now I wish I kept it. I scanned the car completely before it left though. The battery checked out ok.
Old 04-23-2018, 10:12 AM
Thanks for all the info.
Old 04-25-2018, 09:48 AM
Any chance you have a link for the set? Shop said they need to replace valve six but the kit for all of them is 10 days out for ordering. Quoted $1100 + diagnostic hour.
Old 04-25-2018, 10:42 AM
It will be either the 6HP26 or 28 E shift. Check the side of the transmission to be sure.
http://www.thectsc.com/catalog/6-spe...-kits-115.html
http://www.thectsc.com/products/oil-...ce-186-61.html
http://www.thectsc.com/products/mech...p32-42-52.html
http://www.thectsc.com/products/seal...32-214-50.html
The above links are what I used. You need an extra 2L of fluid when you drop the valve body.
Old 04-26-2018, 05:02 AM
Thank you. Any recommended additional services while they have it apart?
Old 04-27-2018, 05:47 AM
Attachment 790888Attachment 790890
End result. Pressure control valve 6 was replaced. All others tested. No further issues with the transmission. Thanks for all Guidance.
Old 07-17-2019, 05:36 PM
Adding some info to my old thread because I finally received the detailed service entry for this repair. I lost the first one. In order to replace the solenoid, the entire valve body is removed and drained. This means that this repair resulted in an entire AT fluid drain and refill. Not just the 1/3 or so you get from a service drain and fill. All valve body sleeves and adapter sleeves were replaced. New pan and filter. This was done at 142,939 miles and I am now almost up to 159,000 miles. Works great.
Old 07-18-2019, 03:02 AM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
A drain and fill is more than 1/3. You get about 6 out of a trans that holds around 10
So 60%.
Old 07-18-2019, 04:41 AM
So 60%.
You’re right. Good correction. Thanks.
