2008 760li - Cannot get heat exchanger back on - Bimmerfest - BMW Forums
Old 07-28-2019, 09:50 AM
smilepl0x smilepl0x is offline
Mein Auto:
I unclipped the heat exchanger from the radiator to investigate a leak and now when I try and push it back on, the radiator gives a little bit and wont clip fully into place. Does anyone have any experience with this? I'm afraid i'm going to break something if I keep pushing.
I would like to hold the radiator in place somehow, but there is a "module carrier" that blocks my access to the radiator from the bottom and I'm not sure how to remove it.
Any help would be greatly appreciated. Thanks!
Old 07-29-2019, 03:48 PM
David.W David.W is offline
Mein Auto: 91 850i, 01 740i, 06 760i
I assume you are referring to the transmission cooler.
My recollection is there is a lever you lift up and then the heat exchanger can be withdrawn from the radiator. There is an O-ring on each of the coolant lines that feed engine coolant through the heat exchanger.
To re-attach you push it on to the radiator and then slide the lever to lock it in.
Old 08-05-2019, 06:39 AM
Mein Auto:
Thanks for the reply.
Yes, it's the transmission cooler that I'm referring to. And yes, there is a lever that is used to attach it with. My issue is that I can't get the cooler on enough for the lever to fully clip it back into place. It just falls off again.
Old 08-05-2019, 07:13 AM
JCMech JCMech is offline
Mein Auto: F10|E66|E38|E34
The top of the carrier has a hook. It need to be hooked on then pressed into place.
