World Premiere: Mercedes-Benz GLE Coupe - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X6 F16 (2015 - Current)
The all new 2015 BMW X6 is the second generation luxury cross over. BMW referes to the X6 as a Sports Activity Coupe (SAC) as it combines the attributes of an SUV (high ground clearance, xDrive and all-weather ability) with the stance, styling and roof line shape of a coupe. The F16 BMW X6 is build side by side with the F15 X5 at BMW's BMW's Spartanburg, SC plant. Read all about the second generation BMW X6 here!
Old 12-10-2014, 08:28 AM
[email protected] Bernie@Bimmerfest is offline
Mein Auto: 83' 323is, 07' MINI JCW+
”gle”
Mercedes-Benz is combining two classes of vehicle – each with its own distinct style – to make a new model, the Mercedes-Benz GLE Coupé. The sporty nature of a coupé dominates, imbued with the striking characteristics of a robust SUV. In addition to convincing on-road vehicle dynamics, the GLE Coupé looks impressive as well. With its flowing side contour, elongated and low greenhouse, striking radiator grille with central chrome louvre and rear end design, the GLE Coupé cites styling features typical of particularly sporty Mercedes-Benz models. At the premiere the GLE Coupé will be available as a diesel or petrol model with an output range of between 190 kW (258 hp) and 270 kW (367 hp). The top-of-the-range model GLE 450 AMG, the first representative of a new Mercedes-AMG product line – the AMG sports models – is particularly attractive. In addition to the generous amount of standard equipment, the DYNAMIC SELECT dynamic handling control system, the Sports Direct-Steer system and the driver assistance systems typical of the brand, the GLE 450 AMG always comes with the 9G-TRONIC nine-speed automatic transmission and 4MATIC permanent all-wheel drive.
”gel”
Successful design synthesis of Coupé and SUV elements
The GLE Coupé not only skilfully embodies the firmly embedded principles of Mercedes-Benz design, but also focuses on the essential features of two entirely different automobile genres. On the one hand, the youngest member of the GLE family bears the decisive, essential stylistic feature of all modern Mercedes-Benz coupés: it combines sheer sportiness with a high-level aesthetic and sensual demand for modern luxury. At the same time, however, elements of the classic SUV are recognisable. With muscular wings, large wheel arches, tyres of up to 55.9 cm (22 inches) and also the high belt line and the generous ground clearance, this model takes the perception of a large, four-door coupé to the next level.
The extreme proportions with superior aesthetics of the new GLE Coupé have emerged from this stylistic gene pool. This is particularly due to the extremely exciting relationship between the low greenhouse and striking body; the silhouette signals dynamism and agility. The upright sports grille with single louvre, framed by three-dimensionally designed all-LED headlamps, is the major feature of the front end with its short, stylish overhang. The forward-sloping bonnet with its typical Mercedes power domes underscores the membership of the GLE Coupé in the line-up of particularly sporty Mercedes-Benz models.
The attractive sports seats and the compact sports steering wheel, as well as the infotainment elements familiar from the C, E and S-Class initially catch your eye in the interior. The information display, which is not entirely free-standing but partially integrated into the instrument panel, attracts attention and is fitted in an optimum ergonomic position. The centre air vents, with a high-grade silver shadow frame similar to the outer vents, are positioned next to the display. The head unit has the same appearance to underline the homogeneity of the interior. The centre console houses the COMAND Controller with the touchpad fitted above in an optimum ergonomic position.
”gel”
In the new GLE Coupé, the developers were able to show the possibilities of the new 9G-TRONIC nine-speed automatic transmission in an all-wheel drive coupé with a longitudinal drive configuration. Depending on the mode selected for the DYNAMIC SELECT variable dynamic handling control system, the 9G-TRONIC impresses with great agility and responsiveness or poised serenity. The potential of the new transmission is exploited to the full. It offers an impressively high shift speed and perfect transitions for energetic sprinting as well as with gentle, barely perceptible gear changes for enjoyable cruising.
4MATIC permanent all-wheel drive always goes hand in hand with safe, harmonious and sporty handling. The GLE 350 d and GLE 400 models feature even torque distribution of 50:50 between the front and rear axles. In the particularly sporty GLE 450 AMG Coupé, this configuration is modified in preference of even greater agility and more pronounced dynamics around the car’s vertical axis, increasing the thirst for cornering. The drive is split in a ratio of 40:60 here. The DYNAMIC SELECT transmission modes SPORT and SPORT+ deliver superior longitudinal agility and lateral dynamics – specifically as a result of the perfect interplay between the modified driving dynamics control systems ASR, ESP® with Curve Dynamic Assist, the electronic traction system 4ETS and the brake control system ADAPTIVE BRAKE.
In addition to the ground-breaking powertrain configuration, the newly designed AIRMATIC air suspension – available for the first time with the continuously variable damping system ADS Plus – guarantees extremely stable driving. The damping system changes its area of emphasis depending on the preselected DYNAMIC SELECT mode. SPORT+ focuses on the greatest possible lateral dynamics with the best possible ride comfort. Conversely, COMFORT mode enables maximum ride comfort with the best possible dynamics.
”gel”
Wide range of output from 190 kW (258 hp) to 270 kW (367 hp)
The GLE 350 d 4MATIC diesel model develops 190 kW (258 hp) and offers maximum torque of 620 Nm from 1600 rpm. The GLE 400 4MATIC petrol model is fitted with the new direct-injection V6 biturbo engine rated at 245 kW (333 hp) and 480 Nm from 1400 rpm. The impressive presence of both models is underlined by 50.8 cm (20-inch) 10-spoke light-alloy wheels with 275/50 R 20 tyres. For those in search of something more sporty, 53.3 cm (21-inch) or 55.9 cm (22-inch) light-alloy wheels with mixed-size tyres can be ordered, although the latter are only available in conjunction with the AIRMATIC ADS Plus air suspension. The chrome-effect shoulderline trim strips and the simulated underguards at the front and rear lend the coupé additional exclusiveness alongside the twin-pipe exhaust system with chrome-plated tailpipe trim. Green-tinted, heat-insulating glass reduces the glare of the sun in the summer, and LED technology features in the headlamps, daytime driving lights, rear lights and third brake light.
The GLE 450 AMG is a particularly sporty choice. The V6 biturbo engine with an output of 270 kW (367 hp) and 520 Nm from 1400 rpm delivers performance akin to a sports car. The DYNAMIC SELECT transmission mode Sport+ is always available in the top-of-the-range model.
The standard equipment here is upgraded with features such as special AMG bodystyling, which includes a specific front and rear apron, a rear spoiler lip painted in the vehicle colour and 53.3 cm (21-inch) AMG 5-twin-spoke light-alloy wheels with tyres of size 275/45 R 21 (front) and 315/40 R 21 (rear). Optionally available here are 55.9 cm (22-inch) AMG 5-spoke light-alloy wheels – also with mixed-size tyres. Excellent traction levels are guaranteed by the impressive tyres of size 285/40 R 22 (front) and 325/35 R 22 (rear). The standard scope of equipment here includes the AIRMATIC package including air suspension and infinitely variable adaptive damping system (ADS Plus) with level control and automatic lowering function at higher speeds, which is optionally available for all models.
”gel”
The GLE is a good looking vehicle, but it looks awfully familiar. I just can't seem to put my finger on where I've seen the styling...could it be the X6? Have a look here and tell me what you think.
ID:	480581   Click image for larger version
ID:	480582   Click image for larger version
ID:	480583   Click image for larger version
ID:	480584   Click image for larger version
bmw x6, mercedes benz new suv, mercedes gle coupé, new gle coupe
