Serpentine belt broke - Bimmerfest - BMW Forums
Old 08-15-2019, 10:10 AM
325bim 325bim is offline
Mein Auto: 2015 535i
2006 Z4 n52 engine, I was able to get home, and after inspection, I donít see an idler pulley, just a tensioner, did they come without idler pulley? I plan on replacing the tensioner and belt, but not sure what parts I need.. confused as searches donít address this
"Mankind requires 4 elements to survive on this planet...
Air, Water, Fire and Sportscar" -Bill Frank
Old 08-15-2019, 10:24 AM
Doug Huffman's Avatar
Nuclear engineer
https://www.newtis.info/tisv2/a/en/e...lement/EmKvkeA
Old 08-15-2019, 10:35 AM
Thanks, but that doesnít represent my engine config, power steering is electric, so no pulley for that. Was the idler pulley deleted, when they went to electric power steering?
Old 08-15-2019, 04:02 PM
wifesauto wifesauto is offline
Mein Auto: sloporsche
turn every pulley and make sure they are free before you replace the belt
Old 08-15-2019, 05:12 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
I canít see the picture you uploaded but I think your electric pump is located on the passenger side of the engine. If so, I would think that you donít have or need an idler pulley and never had one. Your belt would be a different belt from what Doug posted but would follow the same path minus the power steering pulley.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 08-15-2019, 05:43 PM
The difficulty is finding what is the correct part number for the belt, every where I look they either show the belt going around the ps under the alternator with an idler pulley, or describe it as for ac, alt and ps.
Old 08-15-2019, 05:49 PM
Do you have the M roadster, 3.0i, 3.0si, M coupe, or coupe 3.0si?
Sent from my iPhone using Bimmerfest mobile app
Old 08-15-2019, 06:05 PM
3.0i. N52, build date 03/06
Old 08-15-2019, 06:34 PM
I see your dilemma clearly. You either need someone with the same setup to post what they are using or you have to measure yourself with some string and then find the right belt. You can run string along the belt route and then measure.
Old 08-15-2019, 08:53 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
No worries, I have the year and model. On the N52 there is no idler pulley. Serp belt drives only crank, alternator, a/c and belt tensioner. You will need a T60 torx bit on an ratchet/extension to relieve the belt tensioner. Belt is Continental 6K1827 or equivalent. Autozone should have it in stock, as well as the T60 bit.
[SIGPIC]
Old 08-15-2019, 09:18 PM
Thank you! Do u also have the tensioner part number?
Old 08-15-2019, 09:42 PM
This is the one I bought. https://www.fcpeuro.com/products/bmw...em-11287530314
You will also need an E-14 torx socket to remove the tensioner and replace the stretch bolt (included in kit). FCP also sells this kit with the Conti belt included for a little more. This is a pretty easy job once you remove the plastic radiator cover and airbox plumbing for better access.
[SIGPIC]
Old 08-16-2019, 06:45 AM
Thanks again!
Old 08-16-2019, 08:43 PM
[SIGPIC]
