Today on my Bimmer I... - Page 450 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 08-14-2019, 09:52 AM
Alphagrey Alphagrey is offline
His Humble Greatness
Send a message via Yahoo to Alphagrey
Mein Auto: '98 BMW 318i
Changed post-cat Oxygen sensor and removed intake manifold
My '98 318i idles low and rough. My post-cat oxygen sensor never changed from .44v, even after driving for 30 minutes, so I replaced it. Shown below in the attachment, and yes, I have jack trust issues
The new post-cat oxygen sensor did work and change voltage now after warming up the engine, but alas it made no difference in my rough idle. So time to look for a vacuum leak.
Then I took off the upper intake manifold in about 20 minutes using this awesome youtube video ->https://binged.it/2KADFaR to look for vacuum leaks, hopefully I find a cracked hose or something else obvious as I don't have a smoke machine.
ID:	861233   Click image for larger version
ID:	861235   Click image for larger version
Old 08-14-2019, 03:25 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest!
iPhone pictures? I don't know why, but they seem to want to post inverted pictures.
You'll find a "basket of snakes" cluster of hoses under there. The molded "octopus" hose is notorious for splitting.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 09-24-2019, 11:17 PM
nsguajiro nsguajiro is offline
Mein Auto: '99 328i Convertible
Installed a cheapo HUD I had laying around...
and then went to lunch with a pretty girl....
ID:	865673   Click image for larger version
ID:	865675   Click image for larger version
ID:	865677   Click image for larger version
ID:	865679   Click image for larger version
'99 328 Cabriolet 5MT with some ///M things!!!: LSD, short shifter, exhaust, aero, and 3-spoke steering wheel
*Matching beige pitbull not included
Old 11-03-2019, 07:57 AM
oldbmwe36 oldbmwe36 is offline
Mein Auto:
Changed power steering hoses and reservoir
Worked on my 325i. Was pleasantly surprised to see the core work needed really isn't that hard, just need a 22mm socket for the main section, and 10mm for the little bolts, and for the most part that's it. A flathead to break the clips off holding the hoses to the reservoir. Thought it was interesting the cap on the replacement reservoir said CHF instead of ATF, so I swapped back on the original cap so I don't confuse myself later. Will check today to see if it needs any further bleeding. Nice not to have a small drip on my driveway.
Next is to replace the front control arms and other front suspension components.
Old 11-05-2019, 05:51 AM
jamrobin jamrobin is offline
Mein Auto: 07 E83 X3, 99 M3 cabrio
Put her winter shoes and hat on (snows and hardtop).
Don't drive her much once there's snow but I do try and at least go around the block a couple times when it gets down to 40 below and dry to keep things working... Had multiple summer cars over the decades that went up on blocks for the winter and learned my lesson that a bit of winter mileage is FAR better than 7 months of deep sleep.
The X3 got her winter shoes too and is transitioning to daily as the weather deteriorates.
Old 11-07-2019, 07:25 AM
Got her rustproofed
Old 11-25-2019, 07:50 AM
NCSteven NCSteven is offline
Mein Auto: 94 318is
Changed transmission mount, differential fluid, and cabin air filter. Have parts on order for water pump and thermostat, torn down and cleaning it up.
Name:	dirty mount.jpg
ID:	873303   Click image for larger version
ID:	873305   Click image for larger version
ID:	873307   Click image for larger version
Name:	clean plus mounts.jpg
Old 12-01-2019, 12:43 PM
Dio///M's Avatar
Dio///M Dio///M is offline
Mein Auto: E93,E36 M3,E39,E46
Anyone know what could be causing the faint smell of fuel coming from the rear left side wheel well.?
It can be noticed in the back seat sometimes so I lifted the rear bench to see if it could be under the hatch where I think is the Fuel Level Sending Unit, but that area didn't smell at all, so I didn't attempt to open the hatch. Thanks.
Sent from my SNE-LX1 using Tapatalk
Old 12-01-2019, 03:45 PM
D'oh, You Kids!
Open both hatches. Likely you have a perishing fuel hose on top of the tank.
Quotes to live by:
BMW-CCA #441426
Old 12-01-2019, 08:07 PM
Dio///M's Avatar
:3
