M54b25 block with m52b25 head? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-19-2019, 01:59 PM
Nasher16 Nasher16 is offline
Mein Auto: 97 328is
I was wondering if I can use the m54b25 block with my m52b25 head? Also can I put the 3.0 stroker kit in the m54b25 block?
Sent from my iPhone using Tapatalk
Old 09-19-2019, 06:22 PM
southpark11235's Avatar
southpark11235 southpark11235 is offline
Mein Auto: 1999 BMW 323is
You can not swap heads between a M52 and a M54 block. People have looked in to putting a M54 head on their M52/M50 block while doing the M54b30 stroker and if I remember right the coolant passages do not line up.
As far as putting the crankshaft out of a M54b30 in a different M54 block there is no reason you can't do that. You would basically just be making a M54b30 yourself.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
//1992 Mazda Miata - cat delete, power windows, oil filter relocation
We got about ten minutes before this entire county is up in flames. If you want to live, youd better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die! Cartman
Old 09-19-2019, 06:33 PM
Mein Auto: 97 328is
Do you know if the m54b30 motors will fit in e36 chassis?
Old 09-19-2019, 06:51 PM
It will but it is not a straight swap. Look into a S54 swap if you want to know how to do it. That is the popular version of the swap and swapping a M54 would be almost exactly the same. BMW actually put a S54 in the e36 chassis with the Z3 so you can use a lot of BMW parts for the swap. However I would not recommend going through all the effort and cost just to put a M54b30 in. There is a good reason S54 and M52/M50 3.0L strokers are popular and not M54b30 swaps.
Old 09-19-2019, 06:53 PM
Mein Auto: 97 328is
Ok Im prolly gonna do the 3.0 stroker kit. What block should I use?
Old 09-19-2019, 06:58 PM
Mein Auto: 97 328is
Anyone ever bored out the 2.8 to a 3.2 or so? Idk how that works
Old 09-19-2019, 07:07 PM
Your M52 block. A M54 block would turn it into a M54 swap.
It is possible but you would need a S52 rotating assembly. You would basically just be replacing the block of a S52. To make the S52 in the first place BMW just hopped up a M52, so a M52 block is just a bore away from being a S52 block.
Old 09-19-2019, 07:17 PM
Mein Auto: 97 328is
How much power do you reckon a bored out m52 3.2 with 3.0 crank and pistons and a stock m52 head
Old 09-19-2019, 07:28 PM
You would need the S52 rotating assembly to go to 3.2L and you would not need any M54b30 parts. A 3.2L M52 would be the same as a S52 with worse cams, so under 240 HP.
Old 09-19-2019, 07:31 PM
Mein Auto: 97 328is
Whats the difference between the rods and crank?
Old 09-19-2019, 07:32 PM
Mein Auto: 97 328is
The m52 rods and crank vs the s52 stuff
Old 09-21-2019, 02:03 PM
I don't know off the top of my head if the rods are different, but the S52 crank has a longer stroke. The longer stroke and bigger bore/pistons take the S52 to 3.2L over the M52b28's 2.8L.
