Sunroof rattle - Bimmerfest - BMW Forums
Old 10-21-2017, 03:24 AM
glennardo glennardo is offline
Mein Auto: BMW X3 E83
Sunroof rattle
Panorama sunroof. BMW E83 -2007 M-sport
Rattle from rear sunroof + leak when hi-pressure wash.
When driving on a bumpy road there is a rattle from the rear panel. The BMW repair shop said that I have to replace the whole frame. However, I think that sound a bit strange…
When I push the glass from the inside, it lifts about 3mm. If I knock it with my fist I’m able to recreate the rattle/clunk sound which appears while driving.
The guy at the repair shop tried to tighten the visible screw on both sides, but without this changing anything.
Any tips?
Old 10-21-2017, 04:41 AM
swampX3 swampX3 is offline
Mein Auto: bmw++many
there is a tech bulletin
>even the new ones bounce ....there is a ton of info and a tech bulletin on the piano roof saga....strategically placed velcro was the bmw answer
>the leak may cure with a new perimeter weather strip around the glass ....an easy diy
>the leak can be made worse by not having the all 4 corner drains clear.....check/search up all the many many posts on drain cleaning
Old 10-21-2017, 04:44 AM
your homework
>view, study and inwardly digest all the bingoogle info below to become a pano roof phd
>the sunshade panels rattle more when the foam covering starts to deteriorate and looses its thickness....they can be popped out and recovered
https://search.yahoo.com/yhs/search?...bvAJ91Tg%2c%2c
Old 10-21-2017, 04:47 AM
more good FEST pano roof links
https://www.bimmerfest.com/forums/sho...61#post9643561
https://www.bimmerfest.com/forums/sho...=1#post9978752
Old 10-25-2017, 03:47 AM
Duck503 Duck503 is offline
Mein Auto: 2005 X3 3.0i
Problem after problem I finally sealed mine shut with clear gorilla tape 2005 3.0i. sooner or later everything will fail. Kuni BMW of Portland wanted to charge me nearly 3k to to replace the entire cassette.
Old 10-25-2017, 01:54 PM
mtbrdad mtbrdad is offline
Mein Auto: 2018 X3 M40i
Sit in the backseat while someone else drives the car over s bumpy road then you can see what is rattling. While the sunroof shade is open or closed push your hand against it at the back and see if that stops the rattle while you're driving.
