2013 BMW E70 N55 Low Oil Presssure Warning. - Bimmerfest - BMW Forums
Old 02-24-2020, 12:34 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
Had the limp home mode once in the driveway and installed a new BMW Dealer supplied sensor. Was checking out the oil pressure and it is around 35 psi when warm at idle and varies through the rev range. Everything appears to be within specs but it popped a new low oil pressure warning as I was watching the pressure. It cleared and did not come back, YET. I really cannot see why the light should have come on?
Sent via Telegraph wires using my Morse Key.
2001 X5 3.0L SOLD
2013 X5 xDrive35i
Old 02-24-2020, 01:52 PM
ard ard is offline
Resident Curmudgeon
By 'sensor' which sensor did you replace?
Could be a wiring issue- bad connection/intermittent.
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 02-24-2020, 02:26 PM
Zulu95's Avatar
Oil Pressure sensor. I was watching the numbers all the time and there was no low pressure reading. As the DME uses this sensor to trip the code I am baffled as to how it could be popping a code at 37+ psi?
2001 X5 3.0L SOLD
2013 X5 xDrive35i
Old 02-24-2020, 04:03 PM
ard ard is offline
Resident Curmudgeon
By a noisy contact OTHER than right AT the sensor. A loose plug, connector, pin.
I'm not sure why it is so baffling.....
