Video: N54 E61 vs Mercedes E63 AMG Wagon - Bimmerfest - BMW Forums
Old 04-28-2020, 07:57 AM
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Mein Auto: E61
My friend recently picked up a 12' E63 AMG Wagon with the P30 Performance Package, it's stock 550hp 590tq crank.
My E61 is RWD converted, manual swapped, has M5 everything minues the S85, runs Hexon RR550 turbos, ethanol fuel, and a bunch of bolt ons. I have made 550whp 530wtq but the wagon is turned down to 21psi currently.
35-40mph rolls, I stared in 3rd in every gear (in retrospect I should have been in 2nd) AMG owner was trying different gears. Whoever got the jump essentially held the lead, I might have had a tiny advantage up top but hard to tell since the AMG let off a bit early. Either way, fast wagons and good times!
Evan
N54 Powered M5 Wagon:
- M5 Driveshaft, M5 LSD, M5 Axles, M5 Brakes
- M5 Front End, M5 skirts, M5 Mirrors, M-Tech Rep Rear
- KW V3, RD Sport Sways, UR Strut Braces, Forgestar F14 SDC
- Manual Swap, MFactory SMFW, Spec Stg 3+ Clutch, Shiftteck SSK
- EOS Port Injection Manifold, Fuel-It: Stg 2 LPFP +Ethanol Sensor
- N54B30, JB4, Hexon RR550s, Custom Y-Pipe Inlet, AR DPs, 3" Exhaust, VRSF 7" IC, ER CP, Tial BOV, RB PCV, BMS OCC
E39 540iT:
- OEM Style 167, KW V1
- E38 Contour Seats
Old 04-28-2020, 08:23 AM
kd7iwp's Avatar
kd7iwp kd7iwp is online now
Mein Auto: '01 325i, '09 535xi wagon
This is excellent! Beautiful cars, thanks for sharing.
Old 04-30-2020, 10:31 PM
Domni51 Domni51 is offline
Mein Auto: 06 530i, 08 535i
Your car looks/sounds awesome.
1. How much did the manual swap run you?
2. Do you have to remap and change a bunch of stuff for CA smog?
Any information would be greatly appreciated.
Old 05-01-2020, 07:17 AM
ucsbwsr's Avatar
Mein Auto: E61
1. I didn't keep track and I also had upgraded parts like a Spec Stg 3+ clutch and MFactory chromo flywheel so it would be be an accurate anyway. Most people spend ~$3k on a manual swap.
2. This info will stay my info
E39 540iT:
- E38 Contour Seats
Old 05-09-2020, 03:29 PM
I fully understand. Thanks for the reach back.
