Roof drain holes - water outlet valve - Bimmerfest - BMW Forums
Old 04-19-2020, 12:03 PM
MonaLisa MonaLisa is offline
Not Sabine Schmitz...
Mein Auto: BMW X3 35i, Z4M
So - how many folks have just removed the rubber grommet thing at the bottom of the drain hose and left it off? I know it's supposed to block bugs and stuff, but it seems that it causes more problems than it solves. Has anyone had a problem stemming from these things not being there?
....but would sure like to be
Old 04-19-2020, 03:32 PM
wifesauto wifesauto is offline
Mein Auto: sloporsche
removed them on my wifes car 3 years or so ago.....after our 3rd top motor .....no ill effects
Old 04-20-2020, 04:36 AM
RJ237 RJ237 is offline
Mein Auto: 2004 Z4 3.0i
I cut the bottom out of mine. But for those who store the car over the winter, I'd be concerned about mice building a nest in the pocket.
Old 04-20-2020, 06:39 PM
dc_wright's Avatar
I've had mine out for 4-5 years with no issues.
The ID of the drain hose is less than 1/2". They'd have to be micro-mice to get up into the interior through the drain, even with the valve completely removed.
Old 04-27-2020, 01:05 AM
Rob2m Rob2m is offline
Mein Auto: Z4
Mine are out. I think they are more relevant for insects which doesn't really apply in the Uk.
"Today’s ride will remind me forever how good it is to be a motorcyclist, how good it is to be alive and how much we need to live life, rather than watch it pass us by." Green VFR.
Old 05-08-2020, 07:11 AM
RDAN RDAN is offline
Mein Auto:
So I am a little ignorant as to the location. I have had no issues yet on my 2006 z4 3.0si but after reading this I want to remove. Can someone help me out? Thanks
Old 05-08-2020, 01:09 PM
Clearancediver's Avatar
Clearancediver Clearancediver is offline
Mein Auto: 2004 Z4, 2009 Nomad mc
They are in front of the mud flaps. There is room enough to stick your hand up the void/opening to remove them... if your hands are small enough....and you are flexible enough.
It’s a little easier if you jack up the car on each side to do so...
Sent from my iPhone using Tapatalk
Old 05-08-2020, 02:08 PM
Mein Auto:
Thanks I will try this tommorow.
Old 05-22-2020, 02:38 AM
yyz_bobby yyz_bobby is offline
Mein Auto:
I cleaned out my drain holes recently, broke one of the grommets on driver side.
Noticed the road noise straight away and had a member send me a spare. Put both mine back in. Probably one of the rare instances someone does so.
I think getting the car up twice a year to check and clear out any dirt buildup is good enough.
Moving the motor is on the list of things to do so that will not bother me so much if they did get blocked again in future.
Old 05-22-2020, 06:07 AM
Mein Auto:
Thanks, I never got back clear or remove them. Move the motor? How does this work?
Old 05-22-2020, 06:45 AM
Mein Auto:
one of the most spoken about subjects. search threads and google lots of info. Not easy.
Old 05-22-2020, 08:42 AM
Trying to wrap my head around you hearing road noise when you removed your drain plugs. If anything, the removal would create a slight vacuum in the drain line... and given its diameter the chances of it transmitting “noise” would be minimal if my supposition is wrong. If anything I would expect a whistling or slight suction noise.
I noticed absolutely no difference when I did mine.
Old 05-22-2020, 09:45 AM
me too
Old 05-22-2020, 09:46 AM
dc_wright's Avatar
Same here. Absolutely no discernible difference when I took the valves out. First time I've heard of anyone else noticing a difference either.
Old 05-23-2020, 02:18 AM
Mein Auto:
I wear a hearing aid in my right ear so maybe its because the receiver is faced that way, either way you're boring me with your geek level x1000 response.
Each to their own i say
Old 05-23-2020, 04:56 AM
well maybe you did not hear.........that geek is pretty knowledgeable and helpful on this forum
Old 05-23-2020, 05:00 AM
Mein Auto: Z4
I'm guessing the left ear couldn't pick up on that side then!
roof, roof drain, soft top motor
