Rear window shade - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 07-01-2015, 05:07 PM
BossTalker BossTalker is offline
Mein Auto:
Rear window shade
I have a 2011 750I the passenger rear window shade is stuck a.d isn't working a.y suggestions
Old 07-02-2015, 12:45 PM
850destin84 850destin84 is offline
Mein Auto: sandestin
i am looking for the some answer
Old 07-02-2015, 02:48 PM
GHOST PROTOCOL's Avatar
GHOST PROTOCOL GHOST PROTOCOL is offline
Mein Auto: 2014 750ix M Sport
Bring the car in for service?
Old 07-02-2015, 03:35 PM
SeeYal's Avatar
SeeYal SeeYal is online now
In Heaven
Mein Auto: F10 M5/G11 750/2017 320i
Ghost, u r just a smart a$$
Mr. 29,000th...
2017 320i son's car
2017 Chevy Silverado LTZ - Daily Driver
2016 750- wife's car
2014 Chevy Silverado LTZ - Retired
2014 M5 - Toy
2012 750LI - retired
2011 B7 Retired
2008 535i - retired
2008 335i - lease - returned
2007 750li - retired
2004 545i - retired
1999 Chevy Silverado-retired
1991 Chevy Silverado-retired
1989 GTI-retired
1982 320i - retired
1980 Audi 80-retired
Old 07-02-2015, 07:41 PM
Missile Missile is offline
Mein Auto: 2011 740Li
I had the same problem on my right rear passenger side window. It was under warranty so I brought it to the dealer. They had to take the door apart and they screwed it up the first time and had to order the window shade a second time. The part number for my car (2011 740Li) is 51-35-9-168-846. Maybe RealOEM can help. They had to remove my door panel to fix it. The part is over $700, so it's not cheap.
Old 07-02-2015, 09:51 PM
Mein Auto:
Thanks @missle appreciate the advice and info
Old 07-02-2015, 10:22 PM
jgbackes's Avatar
jgbackes jgbackes is offline
Mein Auto: 2014 750Li
I took a look at the "Mitchell 1 DIY" website for fixing that... Pretty complicated.
You should subscribe and follow the detailed instructions found there. http://www.eautorepair.net/Marketing/Default.asp
jeff
Old 06-30-2016, 08:14 PM
thomasverg thomasverg is offline
Mein Auto: 2007 750li
Hello I have a 750li 2007 and both of my passenger sun shades don't come up. I push the button for them to go up and it only rises a little and then immediately goes back down. I removed the door panel and couldn't see anything wrong. Any suggestions on fixing passenger shades to consistently go all the way up and down. Thanks
Old 06-30-2016, 11:20 PM
Sorry I can't help with the repair but did they both stop working at the same time? If they're both only coming up partially and then going back down, then I would look for something in common like a switch or controller or something. It would seem there would need to be separate motors for each shade and I doubt they would both fail at the same time. Have you tried operating each of them individually from the rear door switches? If they work from the rear doors but not the drivers switch then it would have to be something in between.
Old 07-01-2016, 07:06 PM
wjhughes420384's Avatar
wjhughes420384 wjhughes420384 is offline
whughes
Mein Auto: 2009 750li, 2018 X5
my rear shade sticks from time to time, I think I need to lube the top track. when I push the lever arm a little it will go down
2009 750Li - Space Grau Metallic, Camera pkg, Conv pkg, Driver Asst pkg, Lux Seat pkg, Lux rear seat pkg, Prem sound pkg, Sport pkg, HUD, Massaging rear seats, Smartphone integration, Sat radio, MTEC H8 4750K Halo lights,
Dinan Stage 1 SW, Air intake, Free Flow Exhaust, Camber Arm
Old 07-01-2016, 09:23 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
Honda Shin Etsu grease works incredibly well for that.
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
Old 07-01-2016, 10:34 PM
Masoe Masoe is offline
Mein Auto: 2012 750Li/2008 X5 4.8
I had a 2006 750 and I know this is going to sound extra simple, but please make sure the windows in the rear are ALL the way up. I left a little (miniscule) crack in mine and the same thing happened...and don't forget you have to hold the button for a second or so. If it is not that, then I would look at something in common as previously mentioned. good luck.
2012 750Li, Carbon Black Metallic/Oyster&Black, M Sport (Current)
2008 X5 4.8 (Sport), Platinum Bronze Metallic/Tobacco&Black (Current)
2006 750i, Sapphire Black Metallic/Black
2002 745i, Sapphire Black Metallic/Beige
2002 530i (5 speed), Sapphire Black Metallic/Black
Old 07-02-2016, 08:55 PM
Monsterrailroad Monsterrailroad is offline
Almay
Mein Auto: 2013 BMW 750Li
Want the cheapest and EASIEST answer for that issue?
Pay $100-175 to have all the windows tinted and have the back windows at 20% and then you will NEVER need to use those silly sun screens.
Old 07-07-2016, 06:48 PM
Rear window shade
Thanks for all the responses and I've tried them and yes the rear windows had to be up ALL the way and i repaired both in the rear. Thanks everyone.
Old 07-08-2016, 05:30 PM
Cool. What did you do to fix it...someone else may benefit. Thanks
Old 07-08-2016, 09:53 PM
Rear window shade
His rear windows were not all the way up so the shades wouldn't raise.
Old 07-08-2016, 09:57 PM
Donaldo44 Donaldo44 is offline
Mein Auto: 2012 750i M-sport
I had a similar experience early on with my car where my window was down just a hair and the rear shades would not operate. Another unusual "safety feature"Byron BMW.
2012 750i M-sport, coded, BMW puddle lights, rear spoiler
Old 05-22-2020, 04:50 PM
whughes
finally had to replace my rear sun shade, $1500 Parts and labor!!
Old 05-22-2020, 06:46 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
I found a used one on Ebay for around 100.00 shipped. It took around 1 hour to install. The bad thing is I never use it, but it fascinates the grand kids. The shades are just one item that are going to tear up, sooner or later.
Old 05-22-2020, 07:38 PM
whughes
I tried graphic powder and wd40, finally gave up, been nursing this for 3 yrs
Old 05-23-2020, 06:36 PM
Super Moderator
There is a guy on EBAY that sells parts for the screen, to replace the parts that break off. They are made out of aluminum, & priced pretty cheap.
Old 05-23-2020, 08:53 PM
whughes
yeah I already gave the dealer the go ahead
