Adjusting e70 panoramic roof to eliminate wind noise - Bimmerfest - BMW Forums
Old 08-06-2017, 01:52 AM
retrocycles retrocycles is offline
Mein Auto: 2009 X5 SD3.0
I have been searching the net all afternoon trying to find clues on adjusting my sunroof so it seals better. Over 30km/h creates quite a bit of wind noise. If I push up on the front of the sunroof whilst driving, the noise totally disappears. I recall reading of a pair of screws that can be loosened, then after pushing the glass upwards, the screws are tightened again in the new position. Am I imagining this? I read a lot about replacing seals, but can't find anything further regarding the location of these screws. I have done a reset procedure a few times to try to reseat the roof, but it still isn't closing tightly. Anyone able to offer some clues?? Thanks in advance!!
Old 08-06-2017, 03:54 AM
Doug Huffman's Avatar
Nuclear engineer
Adjusting both glass slide/tilt sunroof panel
newTIS.info beta
Home / BMW E70 X5 xDrive35d SAV / Repair Manuals and Technical Data / 54 Slide/tilt sunroof and convertible top / 54 13 Panorama glass roof /
54 13 002 Adjusting both glass slide/tilt sunroof panel
https://www.newtis.info/tisv2/a/en/e...s-roof/HKYgQfO
Old 08-06-2017, 05:01 AM
footballer88 footballer88 is offline
Footballer88
Mein Auto: 2017 Dodge Durango GT
Next year, given the car is still with me, I'm gonna probably take it to the dealer to do The seals around it as they are all dry and cracked. Don't want to mess with a leaky roof.
My noise is screeching from it. Like the 2 pieces of glass is rubbing against eachother when I drive over uneven road. Specifically during cold weather.
Sent from my SM-G935W8 using Bimmerfest mobile app
2017 -- Granite Gray 2017 Dodge Durango GT
2015 -- Silver 2007 BWM X5 4.8i sport pkg totaled
2014 -- Black 2014 Ford Fusion SE Ecoboost 1.5L traded
2013 -- Black 2010 Dodge Nitro SXT 3.7L sold
2013 -- White 2013 Subaru Crosstrek 2.0L wife car
2012 -- Blue 2003 Mercedes Kompressor 2.0L sold
2010 -- Beige 2008 Mazda Tribute 3.0L sold
2009 -- Blue 2003 Mazda Protege5 2.0L sold
2005 -- Silver 1995 Volvo 960 wagon 3.0L totalled
Old 08-06-2017, 07:00 AM
Nuclear engineer
The sunroof is not watertight, the seals are not watertight, and is not intended to be watertight, it is expected to leak. That's what the gutters are for.
Open your roof shade and go through a car wash.
Old 08-06-2017, 07:18 AM
Footballer88
I had the shade open, but never knew about the existence of gutters. Thx Doug! Saved me a bunch of $$$ or embarrassment. Next is to stop the squeeking and get to know any general maintenance to be done on it
Old 08-06-2017, 07:38 AM
Nuclear engineer
I dislike built-in rust holes. So far I have only opened my sunroof and moonroof a couple of times per year to clean and inspect particularly the gutters and lubricate the sliding parts.
Years ago I bought a 1# tube of DC-11 silicone boy-butter that is perfect for this application. BMW even sells a special cleaning tool for the gutters.
~sixty titles with "roof" https://www.newtis.info/tisv2/a/en/e.../search?q=Roof
Old 08-06-2017, 11:50 AM
NoQuarter's Avatar
NoQuarter NoQuarter is offline
Mein Auto: 2008 535xi
I have had 5 series cars for years. I have never considered that the sun roofs are designed to leak. Sure they have gutters to catch some drips or minor seepage but supposed to leak.... I don't agree.
My gutters stay perfectly dry because my seals are are in great shape.
I will inspect the X5 a bit closer but if I see leakage the seals will get replaced.
Saying they are supposed to leak implies there is a spec on how much so the drains can keep up.
Sent from my LG-H820 using Bimmerfest mobile app
Old 08-06-2017, 01:13 PM
Nuclear engineer
Speaking of keeping up, the drain hoses EACH permit 3 liters/minute.
My gutters stay perfectly dry because my seals are are in great shape. I will inspect the X5 a bit closer but if I see leakage the seals will get replaced.
newTIS.info beta
Home / BMW E70 X5 xDrive35d SAV / Wiring Diagrams and Functional Description / Body / Locking and security functions / Slide/tilt sunroof mechanism / Water ingress at panorama roof / Roof operating unit /
Panorama sunroof leaking
"Repair instruction for panorama sunroof
Cause: Water enters through the channel for the drive cable.
Note:Replacing the frame will be ineffective. Replacing the frame will not remedy this problem.
Test instruction: Before the repair, the following check must be carried out:
The panorama sunroof is set correctly.
The all-round seal has already been replaced and has no gaps.
The drain hoses from the panorama sunroof are not soiled.
The drain hoses each permit a drainage volume of 3 litres per minute.
The cause of the leak does not lie at the windscreen.
[ ... ]" [Further repair instructions]
https://www.newtis.info/tisv2/a/en/e...g-unit/YQnWIQX
Old 08-06-2017, 03:48 PM
Thanks a ton Doug. That first bulletin looks like what I need. I'll report back on progress.
Old 08-08-2017, 07:53 AM
NoQuarter's Avatar
newTIS.info beta
HA! that's awesome - Figures BMW would have a spec for that
But I still would not describe it as "expected to leak" especially almost 1 gal/min. If it does leak they have allowed for it. If .8 gal min were leaking through the seal, how does it not quickly become 1 gal/min as it deteriorates further?
either way... this post made me go inspect mine. While i was there I cleaned up the seal and applied gummi pflege.
Old 05-25-2020, 03:28 AM
rafa77 rafa77 is offline
Mein Auto:
perfect
Thanks Doug for sharing the instructions.
It works perfectly! no wind noise
