Windshield Washer Fluid Leak - Bimmerfest - BMW Forums
Old 10-09-2017, 06:07 AM
zuidema.dave zuidema.dave is offline
Mein Auto: BMW 335i Convertible
I have a 2009 335i. About a month ago I had a dealer fill my washer fluid because the warning light came on. Since it's summer, I haven't really had to use it much since then, however when I did try to use it, nothing came out. Then the next day I got the warning that I was low, again. Obviously there was a leak somewhere. I had ordered some OEM fluid by that point, so I filled it back up to see if I could determine where the leak was coming from. There was no immediate leak after filling, so I tried using it again and after I hit the trigger twice, it starts pouring out by the front passenger side tire area. Is this a pump issue?
Old 10-09-2017, 06:10 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Very likely. You can DIY this project. It does require removing the front wheel and fender liner but it can be done. Get a new pump, grommet, and strainer while you are at it.
2014 i3 BEV
2007 328i (E92) - Sold
2013 X5 35i (E70) - Sold
2014 i3 BEV - Lease return
2006 325i (E90) - Sold
Old 10-09-2017, 06:23 AM
Bummer. Thanks for the quick response! I'll have to look at some videos on lunch. In your opinion, is this a fairly straight forward repair? I'm not super handy, but I did recently replace the spark plugs and ignition coils by watching a video and using a very methodical approach. Also, do you know if any special tools are needed? (Like the spark plug adapter I didn't realize I needed when I started that project)
Old 10-09-2017, 07:55 AM
trucky2 trucky2 is offline
Mein Auto: 2009 X5 35d
It is a bit hard to get to but doable. Not sure if yours also has the headlight washer (my X5 does, plus rear window washer) but if it does I would strongly suggest you replace both pumps at the same time. The pumps are about $68 but the labor to get in there is multiple steps.
2009 X5 35d
Old 10-09-2017, 07:58 AM
ramblinman ramblinman is offline
Mein Auto: 2008 335
I just replaced my windshield washer fluid pump last week after it failed. It is a straightforward repair, but you will need to jack up the car and remove the front wheel. Removing the fender liner isn't that complicated. You will need 8 mm and 10 mm sockets. There is a great DIY video on Youtube for the repair with clear step by step directions.
There is a small strainer that fits underwear the pump were it is inserted in the reservoir. Some owners state that their strainer was clogged. I wasn't sure, so I ordered a replacement strainer. Got the pump and strainer from ECS tuning. I removed the reservoir and unclipped the fluid supply hose. Somehow I nicked the line removing it from the reservoir. So be careful if you use a screwdriver to lever the clip back to remove the hose. I had to drain the line, dry it and use some RTV sealant to stop the leak from the hose. It's a $35 part if you have to replace it, which you shouldn't need to do.
Old 10-09-2017, 10:02 AM
BMW4Lee's Avatar
BMW4Lee BMW4Lee is offline
Mein Auto: 2008 335i convertible
This happened to me six months ago. It cost about $150 (parts/labor) to replace the pump at an independent shop. As you already know, replacement requires removal of the wheel and fender liner. Make sure the grommet is replaced as well.
DIY:
2008 335i convertible | Sparkling Graphite | Black Leather | Dark Burl | Sport | Premium | Steptronic | Navigation | Comfort Access | PDC | HD Radio | iPod |
ED Pickup Date: 11/2/07
Departed Bremerhaven: 11/13/07 on the Hojin
Arrived at Port Hueneme: 12/6/07
Cleared customs: 12/14/07
Redelivery: 12/17/07
Old 10-09-2017, 04:35 PM
bocabimmer's Avatar
This is the same level of difficulty as spark plugs and coils.
Get the Febi brand pump from pelican parts and save yourself some money.
2014 i3 BEV
Old 10-09-2017, 04:38 PM
Krynos's Avatar
Krynos Krynos is offline
Mein Auto: '14 F10 550 & '13 F10 528
Seems like a fairly common failure. I had mine fixed under maxcare warranty with a few other things when my water pump finally failed.
Old 10-09-2017, 04:46 PM
ZGator ZGator is offline
Mein Auto: Z3
Yeah, I replaced my pump and gasket a LONG time ago, when your leaks persist, and I think they will, look at the real culprit the headlight washer nozzles, it fixed the leak finally on ONE side, now the other side is leaking, they clog and it pisses out the back of them - easier to get to (than the pump on tank) but OEM nozzles are expensive, I am going to try silicone sealant and a tighter connection via a tie-rap for the other side before I pop for a new nozzle YMMV but I doubt it.
335i 2009, windshield washer leak
