my windshield has thousands of sparkly pits..... - Bimmerfest - BMW Forums
Old 11-04-2017, 01:07 PM
adrose adrose is offline
Mein Auto: 2013 335i convertible
2013 335 i convertible,
now seeing lots of little sparkles ,is it possible its been etched with Rain X?
My car has been professionally detailed about 6 times this year.In FL I can get a new windshield for free....Ive tried to polish but no change.
Any comments?
Old 11-04-2017, 01:12 PM
rbmwiv rbmwiv is offline
Mein Auto: E46 M3
Rain X doesn’t etch. It’s most likely “sand blasted” from driving I have seen many windshields that way replacement is the only fix. Glass is very hard. There for hard to polish. Yes some minor things can be polished but not when they are in that condition. Good luck.
Old 11-04-2017, 01:37 PM
did a search here,found about 20 + replies with the same problem.Ill call my insurance,prob get a free replacement here in FL
Old 11-04-2017, 02:03 PM
Mein Auto: '06 AW 330xi
BMW glass is notorious for being soft and getting pitted easily.
Pits cannot be polished out and after attempting to do so, usually makes it worse since the polish now gets embedded in the pits.
Unfortunately the only fix is to replace the windshield.
If you find your bumpers and headlights are also severely pitted, this typically means you follow the vehicles in front of you too closely.
Old 11-04-2017, 02:49 PM
Yukoner Yukoner is offline
Mein Auto: 2011 328i x-drive
I'm surprised you'd have this issue in FL, but in northern climates where we have sand dumped on the roads for 6 months of the year (to increase traction on snow), this is a very common problem. My BMW's windshield is like this (it also has a large circular crack thanks to a rock impacting it), and will require replacement at some point.
Not even sure if -40 degrees is cold anymore ?
Old 11-05-2017, 01:30 AM
Davein Davein is offline
Mein Auto: 328ix
Sand etched.
Old 11-05-2017, 05:55 AM
CALWATERBOY DUE CALWATERBOY DUE is offline
Banned
Mein Auto: 09 E93 335i somewhat mod
My Ontario relatives regularly visit Florida in whiteout months. They agree: Florida's largely a sand peninsula!
Pines & sand right up through Georgia....South Carolina....but it's you Phoenix boys who know about sand blasting. Yep! Every year, epic Mummy storms....
Old 11-05-2017, 08:02 AM
ramblinman ramblinman is offline
Mein Auto: 2008 335
It's just normal BMW pitting. Doesn't have anything to do with where you live. If you drive at highway speeds no matter where you live, there is grit on the road that gets thrown up in the air. BMW windshield are notorious for pitting more quickly than others. I only notice it when I'm driving into the sun. Polarized sun glasses help dampen the problem. The only fix is a new windshield.
Old 11-05-2017, 08:28 AM
328iblack's Avatar
328iblack 328iblack is offline
Mein Auto: 335is 2011
My car is the same way, I write it off to the car being so low to the ground. Definitely from sand and other debris over the years!
Old 11-05-2017, 10:18 AM
Last time I was down in Maricopa, AZ, we experienced a sand storm. Sat down to eat outside at a Mexican restaurant, 15min later it got what seemed to be really cloudy, then visibility got reduced, then ........
Old 11-06-2017, 09:04 AM
do you hit the front with the parking stops in parking lots? Mine actually cracked,(335i M sport,19" wheels, low profile tires) $2000 to replace...
Old 11-06-2017, 09:06 AM
getting new windshield free on FL insurance today!
Old 11-06-2017, 09:37 AM
Lucky you. We don't really have front glass insurance up here (well, we do, but it's not worth purchasing or claiming on).
Old 11-06-2017, 09:51 AM
Krynos's Avatar
Krynos Krynos is offline
Mein Auto: '14 F10 550 & '13 F10 528
I get it really bad here - constant etching. I normally have to drive into the sun on my way to work, and on my way home so i t can drive me nuts. I just replace the windshield every couple of years. Ive tried (on various vehicles) a mix of OEM and aftermarket glass - nothing can stand up to the 60 freeway here in So.Cal lol
Polishing can help for a while. Really clay bar it clean, then polish with a good compound to fill the pits. But it's very temporary.
Old 11-06-2017, 12:21 PM
jiveturky1 jiveturky1 is offline
Mein Auto: 09 335xi 6MT, 05 M3 6MT
I wish someone would invent the equivalent of Dr. Color Chip for glass. Smear it on to fill dozens of pits at a time, and wipe off the excess.
