E92 Oil level - Bimmerfest - BMW Forums
Old 01-16-2018, 08:57 PM
pastman pastman is offline
Mein Auto: 2007 328xi
E92 Oil level
Hello Members:
My '07 328xi coupe just passed 190K without too many problems. I've noticed that the oil level gauge fluctuates between max and 1/4 qt low (assuming that minimum would be 1 qt low). Is this normal? What are the signs that the sending unit is going? What is involved and what is the cost of replacing the oil level sending unit? Please advise. Thanks.
Old 01-17-2018, 10:31 AM
Porando Porando is offline
Mein Auto: 2011 335i, 2004 X5 4.4L
Have you tried to add 1/4 to 1/2 quart ?
Old 01-17-2018, 10:41 AM
Hello Porando: As it fluctuates to "Maximum", I don't want to take the chance to overfill it. I had read somewhere that these sensors are set to malfunction (by BMW) at 187K. I have 190K, and have noticed no red lights. Do you know what might signal the failure of this sensor?
Old 01-18-2018, 03:19 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Breaking in the Pony
Mein Auto: 19 Mustang GT / 05 Tacoma
A working indicator only has 7 display points:
  • Over a quart low ("+1qts")
  • Min ("OK")
  • 3/4 quart low ("OK")
  • 1/2 quart low ("OK")
  • 1/4 quart low ("OK")
  • Max ("OK")
  • Overfill (">MAX")
Failure of the sensor is indicated by a minimum length bar on the left side of the display and the word "INACTIVE" above it. They do not have a design "self-destruct" mileage.
You're just rocking back and forth on the edge of 2 display points. You're fine.
Prior 44 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92 / 2015 BMW M235xi xDrive F22
Old 01-18-2018, 05:59 AM
CALWATERBOY DUE CALWATERBOY DUE is offline
Banned
Mein Auto: 09 E93 335i somewhat mod
The sensor being a tube shaped capacitor, ain't no movin' parts to break. BUT....can be fooled by water in oil! Driving >10 mi begins the evaporation of condensation, common this time of year.
How boutcha OP - short trips as a rule?
Old 01-18-2018, 08:16 AM
laser's Avatar
laser laser is offline
Mein Auto: 2007 S2000
My 2007 does the same thing ...... the read out is not geanular enough to show 1/8 so itís either full or down 1/4 as the oil level seems to gradually drop a bit between oil changes.
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2017 330i M- Sport Black Sapphire Metallic
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
Old 01-20-2018, 01:30 PM
ramblinman ramblinman is offline
Mein Auto: 2008 335
Erratic oil levels are a sign of a bad sensor. I had the same problem. I didn't want to overfill, so I drained the oil and changed the sensor. Problem solved.
Old 01-20-2018, 02:01 PM
Zooks527's Avatar
3/4 - full - 3/4 - full is not "erratic", it's "the oil level is just around 3/4". The behavior is perfectly normal.
Sure, if you were getting Max-Min-1/4-Max-Min, you would be justified with changing the sensor. If you were getting what the OP posted, you wasted a bunch of money on new oil and a new sensor.
e92 oil level sensor
