328i What is this ticking/knocking noise? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-28-2020, 05:36 PM
btate08 btate08 is offline
Mein Auto: 1996 328i
I drive a 1996 328i and it has a ticking/knocking noise coming from the engine bay. Does anyone know what this could be?
Video:
What I know:
- Coming from the driver side. Appears to be lower
- I notice the most vibration from the noise when I have my hand on the power steering pump
- The noise increases with the RPMs
Out of curiosity/boredom I changed out the old, black power steering fluid, but didn't notice any kind of difference. Any help is appreciated!_a_
Old 05-02-2020, 10:53 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest!
That's very strange. It varies with RPM but is much slower than the RPM. Maybe the CVV?
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
Amateur Extra ham radio operator KO4AXN, see you on 40 meters!
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 05-03-2020, 01:29 AM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
On the 328i, there's a line from the charcoal filter in the trunk that runs up into the engine compartment to a valve that's mounted to the lower area of the left side strut tower. There's another hose that goes from the valve to the intake manifold.
The valve is electronically controlled by the ECU to open and pull vapors from the charcoal canister when the engine is running.
There's been some previous posts where the valve has failed and is randomly opening and closing causing a slow inconsistent speed ticking noise coming from the left side of the engine compartment.
The valve that controls the flap in one of the tail pipes is also located there, and I believe there's been some past posts about that valve ticking also.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 05-06-2020, 04:16 PM
Thanks for the reply! I don't have a ton of BMW experience, but when I've run into evap valves in the past they don't normally sound like this. If you can hear it in the video the thunking sound is consistent. It's actually bad enough for me to feel it in the steering wheel. Idle remains consistent which is making me think it could be something else.
Old 05-06-2020, 04:17 PM
Thanks for the reply! CCV is easy enough to check, so I'll give it a try. The car doesn't have the other symptoms I've read are associated with that though.
Old 05-07-2020, 06:08 PM
So I ran the car and was able to easily remove the oil cap and am not experiencing any other symptoms that come with a bad CCV. Anyone else have any suggestions on what this could be?
Got a better video of it here:
Old 05-14-2020, 06:35 PM
Anybody else have any ideas with the clearer video?
Old 05-14-2020, 07:11 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
Any broken parts on anything that spins? Radiator fan? You can always run the engine without the belt for a minute and see if it goes away. Change with rpms?
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 05-15-2020, 01:31 AM
deroy deroy is online now
Mein Auto: X5 e70 4.8
Id put my money on the serpentine belt itself. Low frequency ticking seems in sync with the belt rotation speed from just this little clip.
Verzonden vanaf mijn iPhone met Tapatalk
328i, e36, knock, power steering, tick
