Bucket seat issue - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 05-02-2020, 05:02 PM
Johnmrose Johnmrose is offline
Mein Auto:
Bucket seat issue
Hi guys Iím new on here and have a Q about installing a bucket seat in drivers side. I own a e36 coupe. Have I got worry about any connections? I.e seatbelt or airbag under the seat? As Iím not going to install a harness and use the original seatbelt. Thanks
Old 05-02-2020, 06:19 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest!
Disconnect the battery before unplugging the seatbelt and/or seat occupancy sensor.
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
Amateur Extra ham radio operator KO4AXN, see you on 40 meters!
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 05-02-2020, 06:21 PM
Mein Auto:
Will I get away with using a resistor on the airbag underneath?
Old 05-02-2020, 10:25 PM
D'oh, You Kids!
I moved your thread to the E36 forum so you can get model-specific help. I have no idea about using a resistor in the airbag sensor circuit. Sounds sketchy to me.
BMW-CCA #441426
Old 05-03-2020, 01:19 AM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
There's no occupancy sensor in the driver side seat, only the passenger seat. Your bigger problem is installing a race seat, but keeping the stock 3 point seat belts. The seat belt pretensioner, which includes the seat belt receptacle, is part of the seat and is attached to the inside frame of the seat. You'll need to figure out how to securely mount it to the mount for your seat.
The other issue is the race seat back has an integral head rest as part of the seat design, which depending on its design, changes the angle of the shoulder belt part of the seat belt. Most times it causes the shoulder belt portion to slide down too low.
The article I linked shows the details of the seat belt pretensioner.
https://www.pelicanparts.com/bmw/tec...eat-Repair.htm
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
