car jump starts but won't charge - Bimmerfest - BMW Forums
Old 05-14-2020, 03:17 PM
bassbo2112 bassbo2112 is offline
Mein Auto:
Yet another battery post! Searched the forums and couldn't find a solution
2007 Z4 3.0si roadster
Hadn't run the car in a while and the battery died. Bought the car last summer so not sure of the battery age. Battery indicator still shows green so hoping its not the battery.
I jumped the car and it started. let it run for a little bit, shut it off, wouldn't restart
Jumped the car again, this time I noticed when I revved the engine, light's flickered, computer rebooted. Left it running for a while while connected to jumper vehicle. Still no luck
I bought the Ctek charger. I've tried connecting the charger to both the battery and the jumper posts under the hood. After about a minute the charger power light starts blinking indicating "the charger has entered the energy save mode. This happens if the charger isn't connected to a battery in 2 minutes"
Appreciate any thoughts
Old 05-14-2020, 05:32 PM
wifesauto wifesauto is offline
Mein Auto: sloporsche
have the battery tested
Old 05-15-2020, 10:19 AM
Mein Auto:
I disconnected the battery from the car, the ctek charger is now charging the battery
Old 05-15-2020, 11:03 AM
Clearancediver's Avatar
Clearancediver Clearancediver is offline
Mein Auto: 2004 Z4, 2009 Nomad mc
Check battery cold voltage ... and then when running voltage regulator output.
Eliminate battery/alternator issues ... then go from there. The battery showing “green” doesn’t mean it’s healthy, especially as you have no history on it.
Changing the battery is a simple procedure and the car battery doesn’t need to be registered. Will need you to reset clock and windows.
Old 05-15-2020, 07:28 PM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Your battery most likely has a shorted cell.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 05-22-2020, 04:40 PM
Mein Auto:
well, it was the battery. Took clearencedriver's advice (as well as some others on the site) and purchased from Autozone, $160. Thanks everyone for your help.
battery, charge battery
