Pittsburgh Automotive Jacks RECALLED - Tell a Friend - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 05-20-2020, 10:20 AM
drmel drmel is offline
Mein Auto: 2014 740Li xDrive
Exclamation Pittsburgh Automotive Jacks RECALLED - Tell a Friend
Not sure if this is the best place to share, but I'm sure a moderator will move the thread if needed.
Harbor Freight, the store we all know and love has recalled over 1.5 million 3 and 6-ton jacks.
You can read more here:
https://jalopnik.com/dont-trust-your...nds-1843546730
https://images.harborfreight.com/hft...1196_61197.pdf
I would suggest getting either Torrin Big Red jacks with the safety pin or a set of Duralast jack stands. Those are the two brands I use.
These forums are communities of DIYers and I'd hate to lose a friend to a faulty jack stand.
Share this news as widely as you can!
Last edited by drmel; 05-20-2020 at 10:23 AM. Reason: Added url to Harbor Freight PDF
Old 05-20-2020, 11:56 AM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Mine were ok but looked the same, T 6905.
Old 05-20-2020, 01:57 PM
Robin750 Robin750 is offline
Mein Auto: 2013 750i and 2015 740i
I would still be wary if they are the racketing type, but like many things, redundancy is still the best bet. If possible, leave the jack under the jacking point without having any weight under it, or slide a wheel under the car.
I've also been thinking about getting a QuickJack lift, as it would make wheel swaps so much faster, but it does take up a lot more storage space.
2015 BMW 740i and 2013 BMW 750i (current)
2011 BMW 750i (previous)
2002 BMW 745i (previous)
2001 Lexus LS430 (previous)
delete pls 8K
*NEW* delete pls 8K
Old 05-20-2020, 03:51 PM
Super Moderator
If the jack stands were to drop, there is still enough room under the car to get out from under it. You might need to go clean your pants out after that happens though? As stiff as our frames are, the weight of 3 other stands would only let the car drop a little, I have seen this when jacking the sides up with the lift pads many times.
A lift is in my near future, just waiting on the right deal!
Old 05-21-2020, 05:35 AM
1bad540's Avatar
1bad540 1bad540 is offline
I have some craftsman stands. I do have a pittsburg jack tho.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,20"s63rims
e70 3.5 aw.mtec,20" 214 whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
w222 S550 amg, dia white
Old 05-21-2020, 07:44 PM
Super Moderator
That is a good jack.
Old 05-21-2020, 08:42 PM
wjhughes420384's Avatar
wjhughes420384 wjhughes420384 is offline
whughes
Mein Auto: 2009 750li, 2018 X5
I have a set of quickjacks. they are great, I just keep them under the car
2009 750Li - Space Grau Metallic, Camera pkg, Conv pkg, Driver Asst pkg, Lux Seat pkg, Lux rear seat pkg, Prem sound pkg, Sport pkg, HUD, Massaging rear seats, Smartphone integration, Sat radio, MTEC H8 4750K Halo lights,
Dinan Stage 1 SW, Air intake, Free Flow Exhaust, Camber Arm
Old 05-21-2020, 08:44 PM
whughes
The quick jacks don't hit the lift points, so I use a couple of 2 x 6 s, one on each side. get the AC units, the DC units require a whole lot of DC, I had to buy two AC to DC converters to power it
Old 05-21-2020, 09:41 PM
That wasn't something I had thought about...are they that much shorter than the wheelbase? Where does the wood contact the car?
delete pls 8K
*NEW* delete pls 8K
Old 05-22-2020, 06:18 AM
Poncherello Poncherello is offline
Mein Auto: 2013 750Li
Good thing I just bought a set of Torin Big Red 6 ton jack stands to replace my 40 year old craftsman stands. Those craftsman stands were great...unfortunately they started rusting on the bottom so it was time to retire them.
Old 05-22-2020, 05:05 PM
whughes
The lift points are more set up for a 3 series, they are about 8 inches short in both directions when I set it up. I center the quickjack then lay a 2x6 on top of it to catch the 7's lift points, Make sure you get the 5 ton model. The 2x6's bend a little but I have never had a problem with it
