2012 Battery Replacement - Bimmerfest - BMW Forums
Old 12-26-2016, 04:18 PM
eeyore8 eeyore8 is offline
Mein Auto: 2012 X5
I plan to replace the original battery in my 2012 35i soon. I have been reading battery threads and have two questions:
1) When I disconnect my current battery, what car settings will I lose (radio, seat memory, etc.)?
2) Will connecting a Ctek charger to the under hood attach points before disconnecting old battery prevent settings from being lost? Or should I connect Ctek directly to battery cables?
I plan to fully charge the new battery using a Ctek after installing then register it using iCarly.
Anything else I should do or know about?
Old 12-26-2016, 05:40 PM
Doug Huffman's Avatar
Nuclear engineer
2) Connect it under the hood and you should lose nothing. Be careful, the battery terminals that you will be working with will be hot with all the current that the CTEK can provide.
One needs to keep the work area as simple as possible.
Fully charge the battery with the CTEK on the bench before installation.
A PIA job from early in my career was removing electric plant control panel meters for calibration, that had to be done 450 VAC hot. We built a rubber room with only a hole in the curtain to work on the particular meter, but it was really cramped. Once I was 'safety' while another guy was working, and he yipped and jumped a half dozen times before we could get him out. 450 VAC hurts.
Old 12-26-2016, 05:43 PM
DieselDonkey DieselDonkey is offline
Mein Auto: 2010 x35d
I didn't lose much when I changed mine.
Just turned wheel lock to lock to reset a message.
Easy peasy
Old 12-27-2016, 08:17 AM
Gold323Ci Gold323Ci is offline
Mein Auto: '12 535, '12 X5, '15 Box
When you replaced your battery, how did you reprogram it? Did you have it done or do it yourself.
I'm not opposed to doing it myself but not sure when it makes financial sense. I have an Ipad and a laptop but the laptop belongs to my employer and it is locked to adding new software.
Thanks!
Old 12-30-2016, 11:01 AM
Mein Auto: 2012 X5
Replaced battery today and registered with carly. Hooked car up to a Ctek while changing and only lost clock settings. 4X4 warning light and message came on after starting car with new battery and turning steering wheel lock to lock cleared that. Total job took 30 min. Thanks for the advice. And battery cost $189.
Old 12-30-2016, 11:18 AM
mkal mkal is offline
Mein Auto: E70 X5
Was CTEK even relevant here as an auxilary source? According to manual, minimum voltage for it to charge a battery is 2 volts, so if the battery was disconnected, CTEK stopped charging and it would explain why you've lost clock settings.
Old 12-30-2016, 12:16 PM
Milliwatt Rob Milliwatt Rob is offline
Fool on the Hill
Mein Auto: x5 xDrive 35d 2013
Rather than a CTEK, I think you would do better to use one of the battery jumper packs as a voltage source when changing your battery.
Old 12-30-2016, 12:20 PM
Mein Auto: E70 X5
Agree. That or any other vehicle with 12V battery.
