Wheel Repair - Bimmerfest - BMW Forums
Old 05-12-2017, 03:55 AM
newyawker newyawker is offline
Mein Auto: 2007 335I Two Door Coupe
Wheel Repair
Hello - I have a 2007 335I 2 door coupe. Can anyone recommend someone that can fix wheels. I have a small crack in my wheel and would like to have the crack fixed. I live in Arlington, VA but willing to travel a few hrs to have a experienced person do the repair. Thanks!
Old 05-12-2017, 06:55 AM
GmanJeff GmanJeff is offline
Mein Auto: 2009 BMW 335xi
I had a bent wheel repaired by Dave at:
Alloy Wheel Solutions, Inc.
14506 Lee Rd. Unit K
Chantilly, VA 20151
703-817-7720
703-817-7723- fax
Open M-F 9:00am 5:00pm
Old 05-12-2017, 07:22 AM
NoQuarter's Avatar
NoQuarter NoQuarter is offline
Mein Auto: 2008 535xi
As crazy as it seems, your local dealer may be the place to ask.
I recently asked my SA for a recommendation on where I could take my wheels for refurbishment. He told he can do it in a 1 day turn around for $160/wheel.
Straightening, curb rash, painting.
They have another company that he told me about that will pick up same day and return them the next.
Old 05-12-2017, 11:23 AM
imtjm imtjm is offline
Mein Auto: 328ix sdn; M240ix cpe
there's no repairing a cracked rim. Buy a new one.
Old 05-13-2017, 06:25 AM
fxrs1955 fxrs1955 is offline
Mein Auto: 2011 335is
I'm sorry but I've repaired many wheels in my time. Never had an issue.
Old 05-13-2017, 12:28 PM
2NASpec's Avatar
2NASpec 2NASpec is offline
Mein Auto: 2012 328i E92
A cracked rim sometimes can be repaired depending on the situation. However, I would not recommend repairing a cracked rim. Especially if you're running a bigger wheel lower profile tire setup. Curb rash and slightly bent rims are very safe to repair. Just my $.02.
Alpine White
Premium pkg
BPC Stage 1 Tune
Old 05-13-2017, 01:25 PM
[QUOTE=2NASpec;10156749]A cracked rim sometimes can be repaired depending on the situation. However, I would not recommend repairing a cracked rim. Especially if you're running a bigger wheel lower profile tire setup. Curb rash and slightly bent rims are very safe to repair. Just my $.02.[/QUOTE
I have 19's and had a left rear wheel repaired, no issues. I've been in the auto repair business for many years, own a couple of shops and I've never seen a problem with a repaired wheel if it's repaired properly.
Old 05-22-2017, 08:39 PM
jsauce jsauce is offline
Mein Auto: 335i
@noquarter where did you go in SA
Old 05-23-2017, 03:23 AM
Bob Shiftright's Avatar
Bob Shiftright Bob Shiftright is offline
Philosopher-king
Mein Auto: E91 mobile beach locker
http://www.wheelcollision.com/
http://www.wheelcollision.com/wccsvcs.html
2008 E91 32K miles, 6-speed, RWD, Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Euro split armrest, V-1 inside rear headrest, Cocomats (with beach sand), $10 clutch stop mod, go-flat tires, plug kit and air pump.
Others include: 1998 Volvo V70 T5 5-speed 220K, original clutch.
"I will give up my stick shift when they pry it from my cold dead hand!"
Old 05-23-2017, 06:03 AM
07335's Avatar
07335 07335 is offline
Mein Auto: 2011 335is CAB w/DCT
The BMW dealer by me is now advertising wheel repair and painting. They had orange wheels on display. I'll pass on that.
Old 05-23-2017, 09:08 PM
do tell what they actually do.
you've repaired a cracked rim many times? Let's define "repair" and "rim".
Old 05-24-2017, 05:22 PM
e9coupe e9coupe is offline
Mein Auto: 2001 M3
99.99% of alloy wheels are cast. Welding a crack in a cast aluminum alloy wheel is not a problem. My first question would be whether or not the wheel is factory and easy to find used, which can be done for about the same price and repairing one. If its a higher dollar wheel and/or aftermarket then repairing is sometimes the way to go.
Old 05-24-2017, 11:26 PM
I hate generic use of terms. Let's define welding. When we talk about welding an aluminum alloy wheel we mean TIG not MIG, and that is the issue with cheap repair jobs. TIG welding an aluminum alloy wheel may not be a problem, but it also may not be the most cost efficient, not to mention that it really depends on the crack.
Old 05-25-2017, 09:44 AM
Mein Auto: 2001 M3
Let's define that the OP is good to go and sounds like he knows what he's doing. I think you might be the only one who cares about the rest...
Old 05-26-2017, 04:42 AM
ramblinman ramblinman is offline
Mein Auto: 2008 335
I had two wheels repaired at http://whlworx.com. Call Mike and set up a time to meet him. He has a large garage behind his house, near the intersection of I-95 and 695 south of Baltimore not far from BWI. He does a lot of work with dealers so he is in and out. He did a great job with two front wheels that were bent and scratched. He can weld and then grind and polish cracks and deep cuts.
