Tailgate Seal Replacement Help - Bimmerfest - BMW Forums
Old 01-07-2019, 01:54 PM
tomfromfife tomfromfife is offline
Mein Auto: 3 series 20d
Hi,
Has anyone replaced the rubber tailgate seal on a F25 X3 ?
I cannot find any videos or instructions online.
Does the lower sill have to be unscrewed and inclipped or can the seal be pulled out and new one installed without unscrewing and unclipped?
Any help would be appreciated.
Old 01-07-2019, 06:39 PM
CoolShirtDude CoolShirtDude is online now
Mein Auto: 2011 BMW X3 2.8i F25 N52
Take a look at this website. Enter your VIN, and it will give you the steps you need to follow.
https://www.newtis.info/
2011 BMW X3 2.8i (F25) N52
2015 BMW 328i (F30) N20
Old 01-07-2019, 10:43 PM
Thanks but I have already been through that site and there is no procedure to replace the tailgate seal.
I would be happy for someone to prove me wrong.
Has anyone actually replaced the seal?
Old 01-10-2019, 04:46 AM
Tailgate seal replaced
OK, I finally tackled the tailgate seal replacement on my X3 F25.
There are no instructions on the newtis site, but it does how to remove the luggage compartment lower sill.
So, go to this page on newtis.....
https://www.newtis.info/tisv2/a/en/f...blind/EWRbYIsy
When you get to the 4th image and you have the adjustable lashing rails installed then ignore that instruction and go here but donít remove the wheel arch covers. Just remove the 2 screws at the top rear of the covers. That will give enough movement to remove other parts.
https://www.newtis.info/tisv2/a/en/f...panel/Hd0ZVNnw
Go back to the first link.
One of the screws under the sill is tricky because of the proximity to the battery but is possible using a small 90 degree ratchet.
In the second to last image on the page it states remove the edge guard. That doesnít appear to be possible so ignore it.
Lift off the sill which is held by 4 clips.
Remove the old seal and install the new one ensuring it is pushed on firmly.
Ensure the vulcanised join in the seal is at the centre bottom.
Reassemble all the trim panels.
The instructions refer to replacing the clips. I had no trouble with any clips breaking.
Old 01-10-2019, 04:47 AM
f25, seal, tailgate, x3
