M Coupe - Bimmerfest - BMW Forums
Old 05-11-2012, 01:16 PM
Grey MCoupe Grey MCoupe is offline
Mein Auto: 2001 M Coupe
M Coupe
New to this forum. Had an M Coupe a few months now, and I really love the car. I've tracked it twice, which was quite a steep learning curve after a WRX! More track days are planned so I want to set up the car correctly. It's also my DD, although I really only drive it maybe three times a week, so i don't want a dedicated track build.
Thus far:
17" x 8 1/2 Kosei's
Michelin SS 245/40/17 all round
Bilstein HD shocks.
Dinan strut brace.
HD control arms.
On order: H&R Sport springs and sway bars.
What else do I need?
Old 05-11-2012, 01:57 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
If you really want a great setup for street and track, call TC Kline.
But the H&R Sport/Bilstein Sport setup is nice. Did you put on a good set of rear shock mounts? Rogue, TC Kline, Ground Control or similar.
A heavier front sway bar is helpful.
Oh, and when you do the springs, swap the hats on the struts. Left hat on right strut and right hat on left strut. Adds a nice bit of negative camber. And free.
Rear subframe bushings will make the car more predictable. The stock ones allow some subframe movement. I like the Ireland Engineering ones.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 05-11-2012, 02:42 PM
Thanks for the tip!
Yes, I have Rogue rear shock mounts.
Thinking about a Conforti chip. I've heard good things about them.
Old 05-11-2012, 10:54 PM
Bucko521's Avatar
Bucko521 Bucko521 is offline
Proud Canadian, I'm Sorry
Mein Auto: 06 Z4 3.0i & 01 Z3 2.5(2)
Originally Posted by Grey MCoupe View Post
Thanks for the tip!
Chips are basically all smoke and mirrors....so not worth it. Most honest review sites would concur!
01 Z3 2.5i Sapphire Black, 01 Z3 2.5i Topaz Blue(SOLD), 06 Z4 3.0i Jet Black
ZSCCA Area Rep and Member - Prairie CruZers
Old 05-11-2012, 11:56 PM
KevinC's Avatar
KevinC KevinC is offline
your average JAMF
Mein Auto: '08 Z4 M Coupé,'16 Golf R
I just put Bilstein HDs on my Coupe last week. Didn't want to go the H&R / Sports direction, because I don't race or do HPDEs and want to maintain ground clearance. Very happy with the results, and these should last relatively forever.
Welcome to our addiction!
'08 Z4 M Coupé LM08602
'19 Golf R
Old 05-12-2012, 09:24 AM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
Subframe bushings...really helps
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
