'98 Z3 2.8L M52 serpentine belt replacement - Bimmerfest - BMW Forums
Old 05-30-2012, 07:00 PM
ALM168 ALM168 is offline
Mein Auto: Z3, e46, Ford Explorer
Hi,
The Bentley manual says to remove the bottom shield and then goes on about taking the tension off of the idler pulley to remove the belts. There is no bottom shield and if there was, I don't see how this would give me any more access to the belts. Do you need to remove the fan and shroud to gain access or am I missing something? I have just replaced the belts, water pump, pulleys, hoses, etc. on my 2000 e46, so I am not a virgin here. I just don't see how to get my hands into front of the engine without pulling the fan, this is not a big deal, but I rather not if I don't have to.
Thanks,
Al
Old 05-30-2012, 07:19 PM
denhugh's Avatar
denhugh denhugh is offline
same but different
Mein Auto: M roadster, 718 cayman
It can be done pretty easily from underneath w/o removing anything. You just have to turn the belt sideways to slip past the radiator. I did it on my 98 Z3 2.8. Just make a simple drawing outlining where your current belt goes (under and over which pulley) and then go for it. I didn't have any trouble removing tension on the idler with a heavy ratchet.
Old 05-30-2012, 09:04 PM
BK85 BK85 is offline
Mein Auto: 97 Z3 2.8
You will still have to remove the AC belt to get the serpentine belt out.
I just did the job this weekend and used the tech guides from Pelican Parts. They were very helpful.. Here is the link, just scroll down to the coolant section.
BK85
http://www.pelicanparts.com/bmw/tech.../tech_main.htm
Old 05-30-2012, 09:07 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
there are two methods to remove tension on the pulleys...one the Pulley casting has a HEX on it that you can put a socket on and then use that to move the tensioner arm.
The other method is to pop the center pastic cap of the pulley and then use a 8mm (IIRC) Allen socket to again force the arm to move.
http://www.pelicanparts.com/BMW/tech...ement/pic9.jpg
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 05-31-2012, 05:47 AM
Thanks. I have only had the Z3 for about three weeks now, and loving it. I will get it up in the air over the weekend and see what it looks like before ordering both belts from BAVAUTO. I have also used Pelican in the past, but receive ground shipments from BAVAUTO the next day.
As for the method to remove the tension, I will see if I have the hydraulic or spring type tension pulleys which will determine if I use the allen key or the wrench. Perhaps I will order a new hydraulic tensoiner if I have the spring loaded one along with the belts.
Al
Old 05-31-2012, 06:52 AM
Benjamin757 Benjamin757 is offline
M52B28
Mein Auto: 1998 BMW Z3 2.8
Thumbs up
A friendly reminder, when you have it up in the air make sure you check the rear subframe. Mine was cracked and I had to Tig weld it back. According to these forums that problem is pretty common.
What would you attempt
if you knew you
could not
fail?
Old 05-31-2012, 06:57 AM
Thanks. I am aware of this issue as it is similar, but not the same, as the subframe failure on 1999 - 2000 e46 (I have a 2000). The failure rate on the e46 is 2%, but I don't know the number for the Z3. Anyone?
Al
Old 05-31-2012, 08:28 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
The E46 issues are NOT limited to 1999-2000 models.
I have repaired a 2003 with the subframe mounting point cracks.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 05-31-2012, 08:48 AM
I agree, but later years had a failure rate of less than 0.1%.
Al
Old 07-20-2012, 01:28 PM
OK, it has been a couple of months since I asked about changing the serpentine belts on my 98 2.8L (M52), and I finally had a chance to get the car in the air today. The AC belt tensioner (hydraulic) has the 8mm Allen hole, but the main tensioner (mechanical) does not have the 8mm hole nor the 17mm hex boss nut to put a wrench on. Has anyone encountered the same with their car, and if so, how did you remove the tension to get the main belt off?
Old 07-21-2012, 08:25 AM
aba4430 aba4430 is offline
Mein Auto: 1987 Subaru Brat
Post
Al
0.1% = 1000 parts per million. Not sure if this should be considered a low failure rate for such systems.
'87 Brat
Old 07-21-2012, 09:54 AM
BeemerMikeTX's Avatar
BeemerMikeTX BeemerMikeTX is offline
Mein Auto: Z3 3.0i Roadster, K1300S
I think the point is that for any one car (i.e., yours) the risk of failure is EXTREMELY LOW.
Mike White
"That's right, you're not from Texas, but Texas wants you anyway." -LL
2001 Z3 3.0i Roadster (Topaz Blue Metallic, 5-speed manual, Sport Package, CD radio, heated seats and mirrors, non-power top via special order)
"Beemer" is for my BMW motorcycles - '13 K1300S, '95 R1100RS, '88 K75S, '75 R90S (gone, but not forgotten).
Old 07-21-2012, 10:33 AM
Post
Not to belabor, but an owner has a 1000 chances in a million to experience the defect. The question is whether this potential defect rate is considered extremely low?
'87 Brat
Old 07-22-2012, 09:45 AM
Back to my original topic......
I used an inspection mirror and found a 16mm headed bolt as the pulley shaft instead of the 8mm Allen that the book describes. Belts changed.
-Al
