Rotor upgrade - Bimmerfest - BMW Forums
Old 06-07-2012, 10:50 AM
Mattochan Mattochan is offline
Mein Auto: 1997 Z3, 2.8, Manual
Rotor upgrade
Hey All,
I'm in the process of doing my brakes. New pads (Akebono) and rotors (Stoptech). The calipers are stock. Does anyone know if the front rotors for the 1.9L are the same as for the 2,8L?
Matt
97 Z3 2.8l
Old 06-07-2012, 09:21 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
use realoem.com to check part numbers but I'm pretty sure the 1.9 is way different.
Also no need to go all crazy with stoptech rotor's plain OEM blanks give plenty of stopping power
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 06-09-2012, 07:19 PM
Pima Roadster Pima Roadster is offline
Mein Auto: 2001 BMW Z3 3.0
No help on the rotor fitment but I do encourage a slotted rotor done right with the Akebono pads. Add a set of SS brake lines & you will have great pedal feel.
Old 06-10-2012, 04:54 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Why a slotted rotor?
About the only thing they do for street use is to increase the pad wear.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 06-10-2012, 12:22 PM
Thanks for the input. They are different rotors for the 1.9 and the 2.8.
