Z3 Rear Window Won't Fold Correctly - Bimmerfest - BMW Forums
Old 07-27-2012, 10:14 AM
Shovel Shovel is offline
Mein Auto: 1998 Z3
I recently replaced my rear window with a BMW factory replacement. Install went very well with instructions from this site. Aligned and zipped in perfectly. The problem is it will never fold down correctly. I always need to stop halfway and straighten it out before closing the rest of the way. I have been using a pool noodle to reduce the crease issue so I generally need to stop halfway to install it but it never bends like it should. It sat in 100+ degree sun the last few weeks, open and closed, which I thought might help but whether in the sun or in the garage, the same problem occurs. Any one else had this problem and found a solution?
Shovel
Old 07-27-2012, 10:33 AM
ZIXXER ZIXXER is offline
Mein Auto: 1999 Z3 1.9 Roadster
Shovel
yeah its the ever present pain in the ass of Z3 owners. don't think there is any cure for it, just drop the top slowly and help the window fold correctly is what i do
Old 07-29-2012, 09:46 PM
DeathFromAbv DeathFromAbv is offline
Mein Auto: 98 5spd Z3 & 99 Explorer
What is the correct way I should be dropping my manual top and having it fold??
Old 07-30-2012, 01:13 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
Got a picture of the top open and half closed ?
Any chance you have a slight crease in the window from the zip being misaligned ?
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 07-31-2012, 11:55 PM
sjdennis sjdennis is offline
Mein Auto: '01 M Roadster, '11 335is
Yup. Mine is the same. Factory window folded and replacement doesn't.
Old 08-02-2012, 07:00 PM
I don't want to have to replace my window any time soon...I would appreciate if someone would demo the best way to fold it properly.
Old 08-10-2012, 12:46 PM
wmcq6 wmcq6 is offline
Mein Auto: 97 Z3 1.9L
if you don't mind me asking,
Where did you get your replacement, OEM?
