Sad, but reminder for all of us DIYers - Page 2 - Bimmerfest - BMW Forums
Old 07-22-2018, 06:30 PM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530i; 2007 328 xit
Originally Posted by adam98540 View Post
Always chock wheels left on the ground and never get under a car only supported by a jack.
My process is to leave the jack in place as a backup once the car is settled on jackstands. Then I slide the wheels under the car as an additional backup.
I do this too, just in case.
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 15+ Years
Old 07-23-2018, 12:36 AM
tstiglich tstiglich is offline
Mein Auto: 2009 528i xdrive
Cribbing Blocks
Originally Posted by banglenot View Post
Poor guy, and to all his significant others, my sympathies.
Consider these: https://www.myturbodiesel.com/wiki/w...o-jack-stands/
(Larger) cribbing blocks are what is used to hold up ships in drydock. These are self made is a few hours.
Unless you're on completely level concrete, jackstands are not as safe as we should use on our cars.
Be safe out there.
Funny, but that same webpage inspiried me to build cribbing blocks a couple of years ago. Two things that I learned though, as I am forced to go around the vehicle and add a block at a time. First, drill a dowell them so that they don't slide when stacked. Second, made sure that the top block of each wheel has stops to lock the wheel in place.
The process is a pain, but once the car is on them, it is not going anywhere.
Old 07-23-2018, 01:24 AM
BudgetBaller BudgetBaller is offline
Mein Auto: E60 5 series
So jack stands for sure should hold right? I had a fear when I first changed my oil but I forced myself to go under after my friend went under like its nothing and the fear is gone in me now until I see this. I did have my car on stands for 3 weeks while I waited on a proper puller for my AC before just settling with a bypass. I plan on DIY fixing my oil leak and servicing my tranny fluid and changing the filter here in a month or two. I dont want to get myself killed because I'm trying to avoid getting ripped off.
2008 BMW 535xi
2003 Audi A6 (rebuilding)
Old 07-23-2018, 02:25 AM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e83, e60
when ever you take the wheel off...
and your going to put the car on jacks or blocks or anything..
you take the wheel and you slide it under the car,
if the jack stand or blocks fail.. the car lands on the rim and tire and you have enough room to survive,
Specializing In Breaking Things Professionally
15486372<-----
Old 07-23-2018, 10:51 AM
militarydave militarydave is offline
Mein Auto: 2009 528i (loaded)
I think of this EVERY TIME I go underneath my car, trusting my life to 2 (or 4) Harbor Freight Jack stands and jack.
Think i'll start a hedge fund to get an actual lift.....
Old 07-24-2018, 07:05 PM
archscot archscot is offline
Mein Auto: 2016 Z4 35is Estoril Blue
Good thread that highlights some of the issues that we can have.
I invested in a set of these jack stands for my Z4.
Have changed tires from summer to winter and back and done a couple of mainenance items.
No issues, they have a plate to fit BMWs and feel safe while working. They are a bit more expensive but worth the peace of mind.
Not sure about the rules about pushing products so wont do any advertising here but if anyone wants more info pm me....
FYI, I do NOT work for the company...just a happy customer.
Also, they are so popular, some major companies have contracts with them, that the deliveries are out a few weeks.
A
Old 07-25-2018, 06:50 AM
bimmer7410 bimmer7410 is offline
Mein Auto: 2003 540i
Same here. I dislike being paranoid about getting under there, so I make sure I have the technique down packed
Old 07-25-2018, 10:29 PM
lobos305 lobos305 is offline
Mein Auto: 325xi
I have always jacked the car up, put at least one jack stand (with pin) under the closest supporting member like an axle, and then lowered the jack down until it touches the jack stand and it takes some of the weight. The theory being that if the jack fails, there is no acceleration of the car as it falls to the jack stand.
