E36 FS: CT - 1995 M3 5-Speed - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Cars - Private Party
Do you have a car for sale? Are you looking for a new BMW? Check here daily as well as searching on craigslist and eBay Motors
Old 11-06-2019, 12:18 PM
sean96gsr sean96gsr is offline
BMW Addict
Mein Auto: F30/E46/E36/F25
For sale is my 1995 BMW M3 with ~117k miles. Asking $16,500. The car is in fantastic shape and has no rust. The car has had most of the common e36 issues addressed or restored since 2016, with the relevant service records available. This car has spent the last 17 years garaged over each winter and has not seen snow. Here are some details & specifics:
Original Books
Original Window Sticker
Some original records
All records from 2016 onward (available to potential buyers)
Clean CarFax (available to potential buyers)
Title in Hand
Extra set of new OEM M3 floor mats
2 keys
OEM Intake in box
OEM Suspension in box
OEM Headlights in box
Original OEM amber taillights, corner lights, side markers in box
4 Apex ARC-8 wheels with nearly new Michelin Pilot Sport 4S tires
Recent Maintenance (2016 Onward)
(05.27.2016, 105k miles)
o Replaced Cabin Air Filter
o Flushed Brake Fluid
o Replaced Radiator
o Replaced Expansion Tank
o Replaced Upper & Lower Rad Hoses
o Replaced Thermostat and Housing
o Replaced Water Pump
o Replaced ACC Belt Tensioner & Pulley
o Replaced ACC & A/C Drive Belts
o Replaced Cooling Fan Clutch
o Replaced 4 Yokohama S-Drive Tires on OE Wheels
o Replaced Power Steering Intake & Return Hoses
o Replaced Front Control Arm Bushings
o Replaced Rear Trailing Arm Bushings
o Replaced Fuel Filter
o Replaced 6 Spark Plugs
o Replaced Shift Shaft Seal
o Replaced Shifter Linkage
o Changed MTF
o Replaced Right Fog Light Housing & Bracket
o Replaced VANOS, gaskets, hoses
o Replaced Crankcase Vent Adapter
o Replaced Left and Right Bumper Trim Panels
o Replaced Left Rear lift block
(08.18.2016, 107k miles)
o Replaced Coolant Level Sensor
(07.21.2017, 109k miles)
o Replaced steering rack assembly along with inner/ outer tie rods, lock plates, rack boots and clamps
o Replaced brake light switch
(02.23.2018, 110k miles)
o Replaced complete oil filter housing
o Replaced Oil pressure switch
o Replaced VANOS sealing rings
o Replaced climate control blower motor
o Replaced catback Muffler w/ Super sprint and with all associated hardware gaskets and mounts
o Replaced complete shifter assembly with UUC Evo 3. Modified new rod joint and Delrin bushings
o Installed weighted ZHP shift knob
o Replaced drivers window switch
o Replaced vehicle battery
o Removed, repainted, and reinstalled both front and rear bumpers plus nose panel
o Installed Euro Clear side Front and Side Markers and taillights
o Installed new radio w/ known good from late, low-mileage Z3
(06.20.2018, 110k miles)
o Purchased Apex ARC-8 Wheels w/ Michelin Pilot Sport 4S tires, mounted & balanced
(11.01.2018, 114k miles)
o Installed Complete Bilstein B8 / H&R Sport Suspension Kit with all associated mounts and hardware
o Installed front and rear strut tower reinforcement plates in conjunction with struts/shocks
o Replaced both left and right front sway bar links
o Installed BMW Motorsport X brace, Front and Rear Strut Braces in conjunction with suspension installation
o Installed MSI Race Wheel studs
o Performed performance alignment
o Replaced drivers side door lock actuator assembly
o Replaced both left and right exterior door handle trims
o Replaced and sealed both door vapor barriers
o Replaced both driver and passenger door panels
o Replaced thermostat housing assembly with OE BMW
o Replaced windshield washer pump w/ grommet
(08.05.2019, 115k miles)
o Replaced timing chain tensioner w/ updated design
o Replaced A/C drive belt tensioner pulley w/ cap and A/C belt
o Replaced water pump
o Replaced exhaust midpipe bracket with all associated hardware
o Replaced complete clutch pedal assembly w/ Turner / UUC delrin bushing upgrade kit
o Performed rear differential fluid service
(10.20.2019, 116k miles)
o Replaced Windshield
o Replaced Headliner, A pillars, C pillars
o Replaced driveshaft flex disc (guibo)
This car needs to be seen to be appreciated, as it's cleaner than any other e36 that I've been been around over the past few years. Needs nothing mechanically, I'd get in it and drive it to California right now without any reservation.
The wheels in the photos are not installed on the car but are included with the sale. The OEM BMW DS1s are currently mounted, with an extra in the spare tire well under the trunk floor. The final photo shows those wheels installed on the car, as it sits today.
Link to IMGUR Album: https://imgur.com/a/JNJjirB
Old 11-09-2019, 09:39 PM
BMW Addict
All PMs replied, bump.
e36, m3
