1998 Bmw 540i - Bimmerfest - BMW Forums
Old 07-01-2008, 07:55 AM
crownpointauto crownpointauto is offline
Mein Auto:
1998 Bmw 540i
When I start my car it sputters really bad, sometimes cutting off if I don't hold my foot on the gas. Once it warms up, it is OK. However, the check engine light has came on and reads P0170 Fuel Trim (Bank 1) and P0173 Fuel Trim (Bank 2). I think this has something to do with the sputtering when it is cold. I have googled Fuel trim and it said it could be a number of things from dirty fuel injectors to this and that. If someone has had this same problem, could you please lead me in the right direction on fixing this problem I have. Thank You for the replies.
BH
Old 07-10-2008, 05:24 PM
bains540 bains540 is offline
Mein Auto: BMW 540i Touring 1998
I had a similar problem which was fixed by replacing my thermostat sensor
V8 POWER DRIVER
Old 07-10-2008, 06:39 PM
stefinn stefinn is offline
Mein Auto:
Take a look at a post I did over on another board back a while ago. It sounds a whole lot like the problem I had with the intake manifold cover (aka CCV, CVV, or EGR valve). When you look at the post, note that I did have a bad camshaft position sensor at the time but that was unrelated to the poor cold-starting.
http://bimmer.roadfly.com/bmw/forums/e39/8054432-1.html
Old 07-10-2008, 06:55 PM
meatrolla meatrolla is offline
Mein Auto: 1997 540i
I have a 97 540 and I had the same problem throwing the same codes. I had my intake resealed because I had a small vacuum leak and it solved the problem, but I think every car is different. I would check for any vacuum leaks or disconnected hoses/worn out hoses before going to the stealership and having them tell you they need to do a $1000 dollars worth of work.
BH
