e39 not changing gear from 3rd - Bimmerfest - BMW Forums
Old 08-01-2008, 11:26 AM
Paul12345 Paul12345 is offline
Mein Auto:
hello
I had my nearside front abs sensor changed and abs light went out....within a 30 miles my gearbox would not change gear once in third (auto), the revs obvisouly high the abs light came back on. took back to garage number of asc fault codes and a "scatter" fault on the abs whatever thats is ..any ideas
Cheers
Old 08-05-2008, 06:53 AM
jeffynor jeffynor is offline
Mein Auto: BMW 520IA
Question e39 not changin gear from third
Paul. My 520iA has a similar problem. The difference is that mine just takes longer to engage to next gear. This happens once in a while, I havent taken it to garage yet.
Old 09-18-2019, 02:21 PM
towertrash towertrash is offline
Mein Auto: E39 530i E70 X5
Try turning off the DSC and see if it changes in the shifting. If not could be in the programming. There is also the possibility that it's just coincidence and tranny is going out.
Old 09-18-2019, 05:23 PM
Chedley Chedley is offline
Mein Auto: 2001 E39 540i
Do you have access to a BMW specific code reader . What are the error codes ??
And how is your battery / alternator . Is it fully charged ??
<=E39=>
Old 09-18-2019, 08:04 PM
mattmar1's Avatar
mattmar1 mattmar1 is online now
Wingnut
Mein Auto: 1999 5281 5 sp msport
ill wager that after 11 years, the problem has been rectified, or the car is no more.
99 528i 5sp sport
be alert...the world needs more lerts
