HELP! Stuttering/Jitter/Hesitation During Acceleration - Bimmerfest - BMW Forums
Old 12-08-2016, 07:01 PM
jmontano95 jmontano95 is offline
Mein Auto: 2008 BMW 335XI
Hello. I am ready to pull my hair out with this and need some input.
I have a 2008 BMW 335XI.
Experiencing Hesitation/Stutter During Acceleration Between 2000-3500 RPM. Almost feels like its misfiring really bad.
I have Replaced
Coils & Plugs
Cleaned VANOS
Done Intake Cleaning
HPFP Was Replaced & Recently Checked By Dealer and was OK.
102,000 Miles. Codes Showing are 0029E0(Mixture Too Lean) and 0029E1(Also Mixture Too Lean). My Spark plugs are all white, and this problem was there before I replaced the spark plugs and coils.
Currently I Have Injector Index 5 & 9.
Had car diagnosed by 3 places.
Place 1 - BMW - Said Valve Cover Cracked(But did smoke test and found no leak?)
Place 2 - Steves European - Said Injectors(Said something about 02 sensors leaning out as it was hesitating)
Place 3 - BMW(Different Dealer) - Said Coils, Plugs Since they are aftermarket & Injectors)
HELP PLEASE!!!!!!
Old 12-09-2016, 05:29 AM
07335's Avatar
07335 07335 is offline
Mein Auto: 2011 335is CAB w/DCT
I am having similar issues with my 2011 335is. Have not made any changes yet. Its odd that it happens in this exact Rev range only but if I run through the gears in a spirited fasion it is as smooth as silk.
I plan to change the plugs but not until the spring unless it gets worse. Right now I have this issue 5% of the time or so.
car has 40K miles.
Old 12-09-2016, 11:46 AM
MMMGP's Avatar
MMMGP MMMGP is offline
Registered Boozer
Mein Auto: E93 335is & E70 35i
OP, I believe the injectors are covered under a 120k/10yr extended emissions warranty, have you checked with your SA?
I had a similar issue, new injectors and HPFP did the trick. I've been down this road.
  1. Cleaned Vanos
  2. Cleaned both MAP sensors located at the charge pipe and intake
  3. Ran through a bottle of Techron Fuel system treatment
  4. New Bosch plugs
  5. New Delphi coils
  6. Carbon cleaning of the intake valves
  7. Injectors and HPFP
'11 335is vert Alpine/Schwarz (1 of 168)
'18 i3S BEV Imperial/Deka (1 of 35)
Old 12-10-2016, 05:07 AM
CALWATERBOY DUE CALWATERBOY DUE is offline
Banned
Mein Auto: 09 E93 335i somewhat mod
Originally Posted by jmontano95 View Post
Cleaned VANOS
Was [THIS] done?
When BMW gave the diagnosis, how did they verify it to you?
Old 12-10-2016, 11:04 AM
MMMGP's Avatar
Registered Boozer
Thanks Cal, will clean this weekend just for fun.
Old 12-28-2016, 06:18 AM
2bmws 2bmws is offline
Mein Auto: 06 330xi 07 328 02 x5
Following and update on this?
Old 12-28-2016, 11:09 AM
07335's Avatar
My car finally turned the CEL on. Code was misfire on cylander 2. I ordered a new coil from FPC and will install Saturday. I should just do the plugs at the same time but will wait for warmer weather.
Old 01-27-2018, 11:43 AM
Babarogue Babarogue is offline
Mein Auto: 323i
Hey 07335, did the replacement of that coil make a difference?
335, 335xi, bmw, hesitation, injectors, misfire, valve cover
